CEN新出4WD MATRIX5-SC 30CC汽油动力 Length: 750mm / 29.5inch Height: 330mm / 13 inch Width: 450mm / 17.7 inch Wheel Base: 520mm / 20.5inch Weight: 15kg / 33 lbs Tire Diameter: 150 x 60 Gear Ratio: 7.68: 1 One metal gear including steering servo CVD flexible bevel shaft All metal gear front or rear diff 4mm stiffened anodized aluminum T6 chassis Universal joint cup suspension system Adjustable with double wishbones 4 step gear reduction system 4 full aluminum oil-pressure shock absorbers Easy adjustable caster angle: 0 to 6 degrees Adjustable camber angle and toe-in angle |
