Serpent 将推出 411 ERYX 3.0 电房
14-4-25 23:04| 发布者: rcfans| 查看: 8326| 评论: 2
Serpent 蛇仔将推出 411 ERYX 3.0 1/10竞赛级电动房车,3.0新车将于5月上市。采用2mm厚度强化带激光雕刻的7075-T6铝制底板,新的轴承托,全新低重心马达座,轻量化差速组件,全新的V2强化合成物料零件,新的A臂和轻量化铝制推杆都出现在411 ERYX 3.0上。
点击这里->进入Serpent 蛇仔品牌专区参与互动
主要特性:
  • 2mm coated and laser engraved 7075 T6 aluminium chassis; dark grey anodised with ERYX 3.0 logo, lowered sides for optimal flex, fully symmetrical for even flex
  • lighter lower bearingblocks front and rear indentical
  • new type lower CG 7075 T6 motormount, centrally mounted
  • seperate bushings to support the top-plate front and rear, to influence flex as needed
  • lightweight aluminium spool with blades
  • v2 type hard composite all around: wishbones, uprights, castorblocks, steeringblocks
  • v2 hard composite wishbones with one central hole for shock mounting
  • rear anti-roll bar mounted in front of rear arm
  • double joint cardan shaft v2 with clips
  • brackets standard :  3.5/ 0.5 split blocks in the rear, 2.0/ 0.5 in the front
  • New material shock-O-rings
  • Lightweight anodised aluminium camberlinks
  • Lightweight anodised aluminium trackrods
  • Lighter composite anti-roll bar centering front and rear
  • ERYX 3.0 set-up sheet
    引用 Allenyan 14-4-28 23:21
    fengshuyu: 电房会用铝制底盘,我反正是第一次看见
    其实,恒龙很早以来都是铝制底盘。。。。。
    引用 fengshuyu 14-4-27 19:59
    电房会用铝制底盘,我反正是第一次看见
