Serpent 411 ERYX 2.0电房
13-1-17 23:29| 发布者: rcfans| 查看: 14688| 评论: 5
Serpent蛇仔推出411 ERYX 2.0 1/10竞赛级电动房车。基于411平台研发而成,设计师Michael Salven,超低重心设计,更轻,车架重量分布更好。浮动式舵机座和全新设计的转向系统,能够有效降低车架扭动对转向的影响。短身RCM(缩短6mm)避震器加入了更软的避震膜可以提升避震工作反应。悬挂组件使用了新的摇臂和C座,提供更佳抓地力。新车未上市已经取得好成绩,Marc Fischer刚刚使用411 ERYX 2.0在DHI杯上夺得季军。
点击->这里进入Serpent蛇仔品牌专区参与互动
Key new items in the 411 ERYX 2.0
- Lighter gear differential with composite gears and coated aluminium out drives; less rotating mass and smoother
- Lowered steering system; for more direct steering feel and lower CG
- Innovative floating servo-holder combined with steering-system; for less flex-influence
- Lower shock towers FR and RR for lower CG, shocks mount 5,6mm lower than before
- Super – Short RCM shocks with new softer membranes (using same springs as before) for lower CG and improved shock action, shocks are 6mm shorter
- New chassis plate 2.25mm for mounting split blocks
- Split suspension brackets inner FR and RR for more flex
- Improved harder suspension arms FR and RR and C-hubs for more traction
- 1mm Lower mid-shaft holder to allow more flex of the top plate
- Kit includes 2 type of aluminium support brackets for the motor mount, allowing more or less flex.
12下一页
    引用 rave1010hk 13-1-20 14:56
    dxl1989: 1/8油铲怎么没反应了!!!!!!
    应该会在2月份德国纽倫堡展览会才正式展示。
    引用 Allenyan 13-1-18 16:29
    传说中的412啊。。。
    引用 dxl1989 13-1-18 10:36
    1/8油铲怎么没反应了!!!!!!
    引用 f19811125 13-1-18 08:54
    没有场地的顶一个~真精致~
    引用 dxjturbo 13-1-17 23:52
    这应该就是TOP RC里面的那辆吧
    查看全部评论(5)
