Tekin具备丰富的RC电子设备开发经验. 新的R1系列电调体积小,重量轻, 但性能一点都不含糊!强大的动力输出, 提供细腻的油门操控曲线.
非常简易的设定流程
温度显示
提供电脑设定界面 *Tekin HotWire
HDAC: 高密度铜FET板
焊接完成的电线接口
自检系统和Reset功能
可调 Drag Brake ...
R1Pro #TT1151 (prototype shown) |
R1 Pro Specifications |
Controls: ON Resistance:
Input Voltage:
BEC: Motor Limit: Throttle Profiles: Brushed: Brushless: Dimensions: Weight: |
Forward / Brake / Reverse 0.00005 Ohms (brushed fwd mode) 0.00015 Ohms (brushless mode) 0.00015 Ohms (brushed fwd/rev mode) 4 - 12 Cells 4S Lipo 6.0 V / 3.0 A None 7 Choices Fwd/Rev, Fwd Only Fwd/Rev, Fwd Only, Rev Delay 1.3 x 1.00" x .60" (33 x 25.4 x 15.25mm) 2.3 oz (with wires) |
R1Pro #TT1150 (prototype shown) |
R1 Specifications |
Input Voltage:
BEC: Motor Limit:
Forward / Brake 0.0001 Ohms (bushed fwd mode) 0.0003 Ohms (brushless mode) 0.0003 Ohms (brushed fwd/rev mode) 4 - 9 Cells 3S Lipo 6.0 V / 3.0 A Brushless: 5 Turn, 36mm can Brushed Fwd: No Motor Limit Brushed Fwd/Rev: 12 Turn 7 Choices Fwd/Rev, Fwd Only Fwd/Rev, Fwd Only, Rev Delay 1.3 x 1.00 x .45" (33 x 25.4 x 11.5mm) 2.0 oz (with wires) | |
