Yokomo BD9 再次复产
19-11-28 12:18| 发布者: rcfans| 查看: 4026| 评论: 5
新闻标题写错了?没有!Yokomo通知BD9 1/10电动房车再次复产,预计本月底开始发货至代理商。这是在Yokomo易主后,首款产品的调整。所有塑胶件在日本制造,并启用新模具,并且换上了一些新铝制和碳纤零件。看来Yokomo认为BD9的战斗力和竞争力仍然在顶尖行列。
NEW!! Aluminum connected center bulk head (Super Narrow)
NEW!! Graphite main chassis
NEW!! Center back born system
NEW!! Aluminum bell crank
NEW!! F/R Long lower suspension arm (New material)
NEW!! Graphite molded front steering block (New material)
NEW!! Molded Front hub carrier (New material)
NEW!! Graphite molded Rear hub carrier (New material)
NEW!! Solid Aluminum servo mount
NEW!! Bearing support stabilizer
NEW!! Light weight/Minimize Gear differential (38T)
NEW!! Aluminum center pulley (20T)
NEW!! Double joint universal
NEW!! One touch battery holder (Glass tape unnecessary)
Aluminum turn buckle
Axon BD 9 exclusive big bore ultra short damper
Axon BD 9 exclusive front progressive spring / rear linear spring
Precision bearing
Includes aluminum and steel screw for bulkhead, upper and lower deck
选购Yokomo产品
https://shopwaigo.com
    引用 pypy4219 19-12-2 08:54
    易主之前塑料件是哪里做的?
    引用 瓶装牛奶 19-11-29 18:53
    是不是因为YOKOMO核心单干了。导致YOKOMO一下无法应对了。。
    引用 大柚子 19-11-28 15:01
    意思就是10遥遥无期?
    引用 henterxing 19-11-28 13:53
    silversol: 显然对中置布局持谨慎态度。 xray:??????
    应该不是,自身出了问题,未能及时调整
    引用 silversol 19-11-28 13:09
    显然对中置布局持谨慎态度。
    xray:??????
    查看全部评论(5)
