Axial RR10 Bomber 2.0 RTR 岩石越野车
20-4-16 21:00| 发布者: rcfans| 查看: 8181| 评论: 40
Axial Racing在2015年推出了RR10 Bomber 1/10像真岩石越野车,和车手Randy Slawson, Bomber Fabrication老板(King of the Hammers rock racing两届冠军)合作。以实车为蓝本复制到遥控车上,Axial还和众多品牌合作,在新车上使用大量实车的原厂授权配件。包括实车授权的管式车架设计、2.2 BFGoodrich Baja T/A KR2轮胎 (S30配方)、Walker Evans Racing轮圈、King铝制避震器等。RR10具备一定的攀爬能力,但也注重行走速度,有别于传统岩石攀爬遥控车。2.0新款的RR10 Bomber今天也正式发布,机械结构并没有进行大升级,遥控设备升级了Spektrum DX3(老款是配Tactic TTX300), Dynamite AE-5L 防水支持3S锂电的电调,标配了尾部红色LED灯条,轮圈也使用了新授权的款式。Axial在经历了Hobbico被收购,中国台湾省代工企业倒闭等阵痛后,已经重回正轨,新款的SCX10 III获得了良好口碑,相信在地平线模型旗下Axial会越来越好。产品编号AXI03016T1(蓝色)和AXI03016T2(灰色)。
特性
– Strong, composite plastic full tube chassis
– AR60 OCP-AXLE with offset pumpkin
– True 4WD locked differentials
– Easy-access, forward mounted, adjustable battery tray
– Strong full ball bearing transmission with all-metal internal gears
– Durable 32-pitch spur gear for high-torque applications
– Aluminum King Shocks with precision-machined pistons (Slawson Bomber version)
– Aluminum Fox Shocks with precision-machined pistons (Savvy Bomber version)
– 4-Link suspension
– BF Goodrich Baja T/A KR3 tires (Slawson Bomber version)
– Falken Wildpeak M/T tires (Savvy Bomber version)
– Officially licensed Trail Ready 2.2 bead lock wheels (Slawson Bomber version)
– Officially licensed Raceline 2.2 bead lock wheels (Savvy Bomber version)
– Metal 23T Servo Horn
– Updated AX31354 Heavy Duty C-Hubs
– Multiple shock mounting points
– Realistic scale details
– Strong WB8 HD driveshafts
– Spektrum DX3 transmitter with Thumb Steer
– Spektrum SR315 3-channel receiver and waterproof receiver box
– Spektrum S614 15kg waterproof metal gear servo
– Dynamite AE-5L waterproof, 3S LiPo capable ESC
– Axial 35T motor
– Four white LEDs on the front, two forward-facing on the light bar and two on the rock lights
– Rear racing-style light bar with two red LEDs
选购Axial产品,请联系酷乐派模型
https://klprc.taobao.com
    引用 BladeRunner 21-5-19 09:30
    哈哈,有人真以为是锁着差速跑的,估计都没开过真实的越野车
    FW190A8: 雷神之锤实车应该有差速锁吧?攀岩路段锁死,戈壁路段开放,难道跑普通路段锁着差速跑?
    引用 xiangbiao 20-9-30 13:00
    专业攀爬要锤子个差速,娱乐车就要差速。
    引用 rwtstarwars 20-5-5 18:23
    没有断传
    引用 gt3gt2 20-4-18 08:35
    前面的灯还挺好看,后面那灯实在有点糊弄人
    引用 hetzer1990 20-4-17 21:24
    gewanlu1: 多看看比赛 十台里8台没有
    没有后差速,但有前差速配气动差速锁啊。话题回到模型上,RR10玩家200%都有在铺装路面上玩过车,不是一出门就有烂路给你跑的,用3S玩这车的人也不在少数,要求一个前差速器不过分且很合理
    引用 gewanlu1 20-4-17 20:08
    hetzer1990: 雷神之锤赛车当然有差速器,用的气动差速锁,不然那么长的高速路段怎么跑?
    锤子前期路段的地形为什么一定要差速?谁规定高速一定要差速 ?当然 差速车也有 但是没有差速为主 baja1000也是没有后差速的
    引用 gewanlu1 20-4-17 20:06
    多看看比赛 十台里8台没有
    引用 hetzer1990 20-4-17 19:54
    gewanlu1: 喷别的方面没升级么倒也合理 该喷 但真锤子比赛的车特么哪来的差速 就有一帮人什么都不懂天天就b啊b的差速差速
    引用 hetzer1990 20-4-17 19:47
    小明锅: 我也是觉得奇怪,攀爬车干嘛老要求上差速?差速到底干什么用的有没有认真研究过?
    RR10又不是纯粹的极限攀爬车,这种车可跑可爬,当然要有差速器了
    引用 Yyy0303 20-4-17 13:35
    先别管真车,这台rr10并不是纯 ...
    引用 煇腾21号 20-4-17 13:14
    里面差速器缺点底盘车架比较低
    引用 gewanlu1 20-4-17 12:21
    没有差速
    引用 小明锅 20-4-17 12:16
    引用 Yyy0303 20-4-17 11:56
    [quote]gewanlu1: 喷别的方面倒也合理 该喷 但真锤子比赛的车哪来的差速 就有那么一帮人狗屁什么都不懂 天天就b啊b的差速差速 玩了几天攀爬 ...
    引用 Yyy0303 20-4-17 11:52
    引用 FW190A8 20-4-17 11:12
    引用 唯特iUnique 20-4-17 11:04
    怎么有人天天嚷着要差速???
    引用 SayidDawson 20-4-17 09:28
    庆幸他们还没要门桥呢
    引用 gewanlu1 20-4-17 09:15
    Yyy0303: 加个灯炒冷饭,起码把遥控锁差速加进去还能有点市场
    喷别的方面倒也合理 该喷 但真锤子比赛的车哪来的差速 就有那么一帮人狗屁什么都不懂 天天就b啊b的差速差速 玩了几天攀爬就觉得自己是越野大咖了
    引用 gewanlu1 20-4-17 09:09
    Tenggis: +1
    查看全部评论(40)
