Tamiya TRF 421 电动房车
24-4-13 16:05| 发布者: rcfans| 查看: 3274| 评论: 12
年初的德国纽伦堡玩具展,Tamiya田宫模型TRF421新一代竞赛级电动房车首次亮相,目前相信这款新车已经进入量产阶段,可能在5月静冈模型展前后上市发售。产品编号为42384的TRF421,Tamiya发布了官方产品照片和特性介绍。
双皮带4WD竞赛级电动房车,采用全新设计的一片式碳纤底板和两片式二楼板,相对于2022年上市的TRF420X车型,马达安装位置前移了22.7mm,实现等长传动皮带,传动中轴以及皮带轮位于车架中心,加速过程中减少抖动,传动输出更稳定。
新设计的波箱也出现在TRF421车架上,进一步降低重心,全新的超短身大容量避震器USBB (ultra-short big bore)固定在铝制避震架。
悬挂摇臂进行了强化,悬挂的长度被增加,提升车架的滚动线性表现,同时转化为更佳的操控响应。
前后防倾杆的安装位置降低到传动轴下方,标配1.0mm和1.2mm。
关键特性:
The Drivetrain uses a front direct coupling and rear oil-filled gear diff. Equal length front and rear drive belts minimize pitch.
Suspension Arms are a rigid “A” design with 7mm longer span compared to the TRF420X for stable roll, while upper arm mounts can be slid to adjust camber. Three damper pivot positions are provided.
Dampers are 5.5mm shorter than on the TRF420X, for a lighter chassis and lower center of gravity. Attach them directly to aluminum mounts and fine-tune with spacers.
    1/10 scale R/C chassis assembly kit.
    The drivetrain features the motor position moved 22.7mm toward the chassis center compared to the TRF420X Chassis Kit and has identical length front and rear drive belts for stable drivability.
    With updated setup of spur gear and drive belts, only one dedicated nut is required to attach spur gear, which enhances efficiency of maintenance.
    The new lower deck is smaller compared to the one used on the TRF420X Chassis Kit to limit ground clearance when the chassis experiences roll.
    Choose from two types (one-piece and two-piece) of upper deck. Changing screw positions allows five setup patterns in total.
    A-shaped suspension arms are employed for higher rigidity. (The 420X chassis kit uses I-shaped suspension arms.) Longer lower arm spans limit swing width and ensure stability when the chassis experiences roll.
    Along with longer lower arm spans, front and rear suspension setups are changed from suspension blocks to suspension balls. Roughly 7mm-longer arm spans limit swing width and ensure stability when the chassis experiences roll.
    Toe angle can be adjusted by uprights. (The toe angle of lower arm inside is 0 degrees.)
    Three attachment damper positions (inner, middle, and outer) on front and rear lower arms are offered by two types of aluminum bushings.
    Changing positions of upper arm mounts by screws allows changes to front and rear caster angles, which is suitable for current high-downforce races. Front caster available angles: 3, 4, and 5 degrees. Rear caster available angles: -.5, -1.5, and -2.5 degrees.
    Dampers are shorter by 5.5mm compared to the 420X chassis kit, which provides an exceptionally low center of gravity and reduces the weight, for a more dynamic driving experience.
    Dedicated damper ends are used front and rear to ensure the same piston level.
    New damper oil seals (Item 51738) are used to keep the maximum oil amount and to make use of oil dampers efficiently.
    While the 420X chassis kit uses carbon fiber damper stays, this chassis kit employs aluminum mounts for precise angle adjustments based on the number of spacers used.
    Front and rear differential pullies are newly molded while direct coupling and oil-filled gear differential are employed at front and rear, respectively. (The currently sold Hop-Up Option and Spare Parts can be used.)
    The front features double cardan joint shafts while rear employs lightweight universal drive shafts. New axle shafts (Item 42388) and 45mm drive shafts (Item 42387) are also used for both front and rear to ensure efficient drivetrain and maintenance.
    Newly designed lightweight rear wheel axles enhance durability.
    Precision stabilizers are attached at a lower position than drive shafts for efficient maintenance of drivetrain. Includes 1.0mm diameter (x1), 1.1mm diameter (x2) and 1.2mm diameter (x1).
    The steering system pairs dual steering arms and Ackerman bush with a new steering bridge.
    Three types of new spacers featuring different diameters allow steering angle adjustment.
    Includes Sealed Ball Bearings from the TRF series for efficient rotation and Item 22078
    Aluminum Differential Holders (0.8mm Offset, 2pcs.).
    The newly molded quick-plate design battery holder does not require tape for attachment.
    Depending on the battery pack equipped, change positions of spacers and posts. Shorty pack compatible.
    Comes with a carrying case dedicated to the TRF421 chassis kit.
选购Tamiya产品请进入
    引用 wanghaotian 24-4-22 11:11
    mugen强啊  田宫、youkomo都仿
    引用 叫啥都重名 24-4-19 18:01
    太草率了!转向杯的球头螺纹高出那么多
    引用 就是不玩车 24-4-19 05:23
    老田真不行了
    引用 BanDai 24-4-16 18:41
    肉眼可见的保守甚至是落后
    引用 luyiqi14 24-4-16 09:23
    是复刻还是新车架
    引用 广州威少 24-4-15 22:52
    四轮转向?
    引用 我叫BMT 24-4-14 15:35
    a800还是出得太早了
    引用 老男孩Ym 24-4-14 06:30
    好东西呀,哈哈
    引用 a564587669 24-4-13 21:43
    我选蓝色
    引用 yokomorc 24-4-13 18:49
    现在创新都是相互借鉴,风格略同,结构略同,都差不多,挤牙膏
    引用 紫梵 24-4-13 17:35
    可以预见TRF421X是MTC2R
    引用 看妮妹 24-4-13 16:16
    蓝色mtc2{:狗狗:}
    查看全部评论(12)
