Tekin 电调系列
06-10-10 21:08| 发布者: admin| 查看: 1543| 评论: 0
Tekin R1 Speed Controller
Tekin R1 Pro Speed Controller
First look at the all new R1 and R1 Pro 10th scale brushless esc. A great big controller in a small package.
Size approx 1.25 x 1.25 tons of features, On-Board program, throttle adjustments, drag brake adjustments, motor timing and that is just for starters.
Keep checking back for more information.
Tekin B1 Speed Controller
Tekin B1 Reverse Speed Controller
The B1 and B1R is Tekin’s continual commitment to the Micro market.
The B1 and B1R are both built on the same base the only difference is that the B1R has reverse.
The B1 and B1R both support up to 8 cells and is the first in the brushed micro market that will support li-po cells. These esc’s can support up to 3 li-po’s and has no motor limits.
The B1 and B1R features Tekin’s exclusive on-board programming with its patented LED lights, soldering post for easy wire placement and replacement, throttle adjustment, drag brake adjustment, and voltage cutoff and Tekin’s exclusive Punch Control and all new Anti-Drag adjustments and it is sits in a 1” x 1” footprint.
More information will come as it is available. The target date for the B1 and B1R is October
