Tekin R1 Pro Redline Mod 3-7.8 Brushless System[Tekin无刷]
07-4-18 23:01| 发布者: admin| 查看: 1189| 评论: 0
Tekin推出一套无刷系统,名为R1,厂方宣称该无刷系统无论从性能和重量都较市面上RC用无刷系统优胜!厂方参数:
FEATURES:
Easily Access All Programming, Anywhere, Anytime
On-Board Temperature Indicator
PC Interface for Custom Programming *Tekin HotWire Required
HDAC: High Density Copper Fet Boards
Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Adjustable Drag Brake
Pit Tune Mode
Digital Glitch Filtering
QuickTune™ One-Touch Programming
One-Touch Radio Calibration
PROGRAM FEATURES:
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none, 12 steps)
Neutral Width (7 steps)
Throttle Profiles (7 choices)
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2S, 3S, Custom)
Extensive Tuning via Tekin HotWire PC Interface (sold separately)
