Associated RC8Be Factory Team kit
10-5-4 08:48| 发布者: admin| 查看: 3693| 评论: 0
assorc8befactory-1Team Associated 正式发布RC8Be Factory Team kit, 在RC8e 基础上加入了大量的高强度升级零件,加入了大容量Factory Team 16mm 避震,5mm厚度7075底板、油压架,一体化马达座,更多照片在本文内。 RC8Be Factory Team Kit Features: - Pre-assembled shocks, diffs, and turnbuckles with Factory Team shock and diff fluids included - Factory Team 16mm Big Bore threaded, hard-anodized shocks feature heavy-duty 4mm TiN-coated stainless steel shock shafts for maximum smoothness - Updated 5mm 7075 blue aluminium shock towers allow the driver to stand the shock angle up for a more aggressive suspension - Optimized front upper camber link bushings allow for easier tuning and maintenance - 7075 blue aluminium suspension mounts front and rear - Molded bushings allow for easy and quick adjustment of rear toe-in, rear anti-squat, and front kick-up - Optimized steering geometry for more consistency and reduced bump steer - Updated wing mount with additional clearance for 16mm shocks - Molded battery tray supports two R.O.A.R. approved 1:10 scale size 7.4v LiPo battery packs with room for foam pads - Molded composite front and rear chassis braces - Factory Team 83mm wheels, Pro-Line M3 Holeshots with molded inserts included - Lightweight blue aluminium motor mount - Factory Team 7075 blue aluminium one-piece top plate - Lightweight 3mm hard-anodized chassis - 4.30:1 ratio gearboxes for maximum punch - Two-piece split-center diff mount allows quick and easy access to the center diff - Caster blocks adjust 14°, 16°, or 18° with molded inserts - 3.5mm light CVA drivetrain with full ball bearings - Rear molded CVA boots to keep dirt and mud out of rear joints - Blue aluminium hexes and nylon locking wheel nuts - Tough steel-alloy shock stand-offs Source: Associated [rc10.com] & Redrc.net
