Associated RC8B升级零件
11-5-2 16:48| 发布者: admin| 查看: 3286| 评论: 1
Associated为他们的RC8B越野车推出升级零件,这些零件已经通过了AE厂车手的长期测试,包括去年在泰国举行的世界赛,现在这些零件不再是车队独有,普通玩家也可以拥有了。升级零件包括一块新底板(+3mm),轻量化的头尾轴杯,升级的前后摇臂,头尾油压架等,详细升级零件列表请看本文,预计这些零件最快在6月上市。
UPC Part # Description MSRP
784695894761 89476 RC8B +3mm Chassis $99.99
784695894877 89477 RCB Light Outdrive, front $19.99
784695894785 89478 RCB Light Outdrive, rear $19.99
784695894792 89479 RC8B Upgrade Front Arms $16.99
784695894808 89480 RC8B Upgrade Rear Arms $16.99
784695894815 89481 RC8B Low B Plate (includes inserts) $19.99
784695894822 89482 RC8B Low B Plate Insert $2.99
784695894839 89483 RC8B Upgrade Front Tower $25.99
784695894846 89484 RC8B Upgrade Rear Tower $29.99
784695894853 89485 RC8B Aluminum Steering Posts $10.99
784695894860 89486 RC8B Rear Swaybar Kit. (Use with #89480 Upgrade Rear Arms.) Includes rear swaybars 2.5, 2.6, 2.7, 2.8, ball joints, set screws, swaybar retainer eyelets $18.99
784695894877 89487 RC8B Rear Swaybar, 2.5 green $3.99
784695894884 89488 RC8B Rear Swaybar, 2.6 white $3.99
784695894891 89489 RC8B Rear Swaybar, 2.7 blue $3.99
784695894907 89490 RC8B Rear Swaybar, 2.8 yellow $3.99
784695894914 89491 RC8B Suspension Upgrade Kit. Includes front and rear towers, modified front and rear upper and lower arms, straight eyelets, M3 x 22 button head cap screws $59.99
欢迎进入RCFans越野车讨论区参与讨论
http://www.rcfans.com/bbs/forum.php?mod=forumdisplay&fid=5
Source: Associated [rc10.com] & redrc.net
    引用 reiyagami 11-5-4 08:39
    这些个 必须入
