Losi Night Crawler Bind-N-Drive
10-5-4 08:58| 发布者: admin| 查看: 5704| 评论: 0
losinightcrawlbnd-2现在市面上的部分攀爬车需要进行升级改造后才能进行岩石攀爬,而Losi这辆 1/10 Night Crawler BND 原装车就已经具备了良好的攀爬性能!玩家只需要绑定DSM(2.4g)遥控设备就能马上拥有一辆高性能的攀爬车!这套产品包含了锂电、预设攀爬程序的专用电子变速器,540-55T大扭力马达,详细资料在本文内。 Specification: Type: Rock Crawler Scale: 1/10 (2.2) Length: 444.5mm (17.5 in) Width: 250.8mm (9.875 in) Wheelbase: 312.4mm (12.3 in) Weight: 1.9kg (4.18 lb) Chassis: Aluminum twin vertical plate Suspension: 4-link Tyre Type: 2.2 Losi Rock Claw tyres Motor or Engine: 55T/540-sized motor Speed Control: Losi MSC12L Fwd/Rev LiPo-compatible with crawler programming Radio: Included Losi receiver with Spektrum 2.4GHz DSM technology Wheel Size: 2.2-inch beadlock Kit/RTR: BND Shock Type: Adjustable 4-inch aluminium, coil-over, oil-filled Body: Pre-decorated Grappler Pro Features: - The front and rear solid axle features a worm gear drive that acts as a brake when no power is supplied - The included ESC, with crawler-specific programming, accepts NiMH and LiPo batteries - All-metal CV front axle and centre driveshafts provide superior durability to the driveline to handle the stresses of rock crawling - The included Losi receiver with Spektrum 2.4GHz DSM technology means you’ll never have to worry about radio interference - The included front and rear LED light set comes pre-wired and mounted to the chassis - 4″ adjustable aluminium shocks provide durable, smooth operation and maximum suspension articulation without binding - The crawler features a low-centre-of-gravity battery tray design that allows for multiple battery types—from NiMH and LiPo “stick” packs to any of the 2.2-inch Losi LiPo crawler battery packs - The molded 4-link suspension setup minimizes rear axle swing and provides more precise handling - True 3-piece 2.2 beadlock chrome wheels, with 12mm hexes, hold the tyre bead in place and let you change tyres if needed—all without glue - National Champion 2.2 Losi Rock Claw tyres with foam inserts are constructed with Losi’s blue compound and have the characteristics, grip and traction to scale even the toughest courses - The direct-drive transmission provides an ultra-low gear ratio for rock crawling and metal outputs for durability - The twin vertical plate chassis is anodised red for a custom look - Zero Ackerman steering provides class leading performance with 45 degrees of steering throw - The competition-legal Grappler Pro body features realistic looks and added functionality Source: Horizon Hobby [horizonhobby.co.uk] & Redrc.net
