Team Losi Racing 22T竞赛卡车
11-8-12 21:12| 发布者: admin| 查看: 4373| 评论: 2
Team Losi Racing(TLR)的22电动越野车相信大家都听说过,22电越具有中置或尾置马达两种设定,在22车架基础上TLR开发出22T竞赛电动卡车。22T成为世上唯一支持中置和位置马达两种设定的电动越野卡车,车子的场地适应力大大增强!22和22T两台车有75%的零件通用,强化的铝制车架,12mm大容量避震器,大尺寸轴承都被用在22T新车上。 相信22T具有很强的战斗力!
欢迎进入RCFans越野车讨论区参与讨论
Features
- Hard 2.5mm anodised aircraft Aluminium truck chassis
- Removable plastic dirt guards
- Fully milled for weight reduction
- Maximized chassis length and wheelbase
- Supports multiple battery configurations
- Weight balanced
- Improved component durability through materials and design
- Rear- or Mid-Motor Completion
- All required completion parts included for either configuration
- 3-gear rear-chassis transmission (Low to medium traction surface)
- 4-gear mid-chassis transmission (High traction surface)
- Fully adjustable caster via the spindle carriers
- Allows for fine tune adjustment for on/off-power steering
- Hard anodised 12mm shocks with bladder compensation
- Provides increased handling over bumps and improves handling
- TiNi shock shafts for durability and smooth operation
- Molded shock tool included
- Best in class front nose clearance
- Improved handling entering ad exiting steep jumps
- 3.5mm turnbuckles for increased strength
- Adjustable Caster (0, 3, 5, 10°)
- Adjustable Spindle Carrier Position (Front or Trailing)
- Stock at 30o, Adjustable front kick to 20 or 25 degrees
- All metric hardware, only one set of tools required
- Unsurpassed tuning and adjustability
- New 1/10-scale truck wheels included (2 sets, tyres not included)
- 2 ROAR legal truck bodies included
    引用 胖龙 11-8-15 11:11
    给人感觉翻车的可能型 ...
    引用 邦德座驾 11-8-13 15:37
    很想玩玩这样的后驱越野卡车。
