Losi 1/10 22T 2wd RTR卡车
12-1-15 14:08| 发布者: admin| 查看: 8478| 评论: 4
美国Losi推出全新1/10 22T 2wd RTR电动遥控卡车。这辆22T卡车装载了13.5T有感无刷马达,Sprktrum DX3E遥控和SR300接收机,这套遥控设备为三通道,LED电量显示, 2.4GHz DSM®技术等都在这套设备上出现。大扭力转向舵机让22T的转向反应更灵敏。12mm铝制可调油压避震器,2.5mm 7075 T6铝制底盘提供坚固的车架基础,让22T遥控车轻松应付各种越野地形。两种颜色的涂装供玩家选择,分别是白色和黑色。虽然是RTR产品,但是玩家还需要额外添置动力电池和充电器才能启动这辆遥控车。这辆Losi 22T 2wd卡车相信是一辆充满乐趣,适应能力强的中级产品。
Features:
2.5mm low-center-of-gravity aluminum chassis
Losi® 13.5T sensored brushless motor
Losi programmable, sensored ESC with LiPo cutoff
Ultra low resistance, high-power EC3™ connectors
Spektrum SR300 receiver with 2.4GHz DSM® technology
12mm threaded aluminum, oil-filled, coil-over shocks
Losi extra high-torque steering servo
Sealed viscous gear differential
Adjustable dual-disk slipper clutch
Full ball bearing equipped
Gull wing suspension arm design (front)
Pre-mounted race-compound tires (BK-Bar)
Secure battery straps
3.5mm heavy-duty turnbuckles
Innovative steering rack design
Three-channel surface system
Spektrum™ 2.4GHz DSM® technology
Two-position, three-position or linear auxiliary setting
Steering dual rate knob for easy adjustment
Independent travel adjustment dials for all three channels
Battery voltage level indicator LEDs
Servo reversing on all three channels
12下一页
    引用 入了mo界 12-1-15 21:06
    没个车样   车宽标准??
    引用 tjchen2008 12-1-15 17:46
    要是 四驱的 多好。。。  ps:前脸太恐怖,。。
    引用 shi995800 12-1-15 16:43
    这个脸把我吓着了
    引用 zch 12-1-15 14:50
    配置真高啊
