Reds Racing 推出R5 .21 Buggy引擎。这是一颗5port轻量化引擎,ABC,适合各类赛道使用。重量只有348g,全瑞士制轴承,轻量化散热顶,相信很快这款引擎会进入中国市场。
Features - Ultra-light, only 348g - 5 Ports hard chromed liner - CNC machined billet piston - New separated and cooled combustion chamber - Lightweight cooling head - 14mm crankshaft - Knife edged aerodynamic connecting rod - All Swiss Made ball bearings - New long needle composite slide carburetor
Specifications - Displacement: 3,5 cc - Bore: 16,26 mm - Stroke: 16,80 mm - Weight: 348 g |
