Reedy Sonic 540 Mach 2 无刷马达
13-2-18 21:17| 发布者: rcfans| 查看: 6484| 评论: 5
Reedy推出全新Sonic 540 Mach 2无刷马达,提供四个版本,分别是10.5, 13.5, 17.5和21.5。Reedy这款新产品已经在JConcepts Winter Indoor大赛上被厂车手使用,全新合金尾盖替代了老款的塑胶产品,更坚固更精准。马达的冷却效能更佳,内部使用了新尺寸轴承,使用新轴承后还可以获得更高转速和提高可靠性。
Features
  • Lightweight design
  • Optimized air flow
  • Dual precision ball bearings
  • High-strength balanced sintered rotor
  • Adjustable timing with alloy end cap
  • Silver-plated solder tabs
  • Completely rebuildable
  • Competition proven
  • 200mm sensor wire
  • Ultra smooth, sensored operation
  • Built to ROAR, EFRA, and IFMAR specs
Specifications
Cells 2S LiPo, 6-cell NiMH
Diameter 35.8mm
Length 52.9mm
Shaft Diameter 3.17mm
Weight 175-185g
Available Feb. 2013
#231 Sonic 540 Mach 2 21.5 Spec
UPC: 784695 002319
#232 Sonic 540 Mach 2 17.5 Spec
UPC: 784695 002326
#233 Sonic 540 Mach 2 13.5 Spec
UPC: 84695 00233
#234 Sonic 540 Mach 2 10.5 Spec
UPC: 84695 00234
#235 Sonic 540 Mach 2 9.5 Modified
UPC: 84695 00235
#236 Sonic 540 Mach 2 8.5 Modified
UPC: 84695 00236
#237 Sonic 540 Mach 2 8.0 Modified
UPC: 84695 00237
#238 Sonic 540 Mach 2 7.5 Modified
UPC: 84695 00238
#239 Sonic 540 Mach 2 7.0 Modified
UPC: 84695 00239
#240 Sonic 540 Mach 2 6.5 Modified
UPC: 84695 00240
#241 Sonic 540 Mach 2 6.0 Modified
UPC: 84695 00241
#242 Sonic 540 Mach 2 5.5 Modified
UPC: 84695 00242
#243 Sonic 540 Mach 2 5.0 Modified
UPC: 84695 00243
#244 Sonic 540 Mach 2 4.5 Modified
UPC: 84695 00244
#245 Sonic 540 Mach 2 4.0 Modified
UPC: 84695 00245
#246 Sonic 540 Mach 2 3.5 Modified
UPC: 84695 00246
#247 Mach 2 Sensor with bearing
UPC: 84695 00246
#248 Mach 2 Steel Bearing Set
UPC: 84695 00246
#249 Mach 2 Ceramic Bearing Set
UPC: 84695 00246
#250 Mach 2 Insulator Set
UPC: 84695 00246
http://www.teamassociated.com/pictures/news/articles/1080/supporting_photos/3-sonic-motors.ps_lg.jpg
    引用 yangyi2329 13-2-20 00:14
    看着就变态
    引用 牛逼 13-2-19 18:06
    報價
    引用 kly520 13-2-19 15:37
    毒物呀.........
    引用 zb2759 13-2-19 03:27
    电房,12仔,F1
    引用 f19811125 13-2-18 23:20
    够毒的,谁能告诉我,这3款都适合跑什么
    查看全部评论(5)
