Kyosho Ready Set DMT VE-R 4WD大脚车
13-3-28 12:31| 发布者: rcfans| 查看: 8921| 评论: 9
Kyosho京商对他们的DMT VE大脚车进行了升级,加入了支持3S锂电的Orion Vortex R10电子变速器和Orion无刷马达。 使用了新的动力设备后,车速全面提高,可达60mph以上。高效强壮的四驱传动系统,使用三差速设计。大容量避震器,高抓地力轮胎,全新的转向组件布局,DMT VE行走性能大幅提升!
点击这里->进入Kyosho京商品牌专区参与互动
http://cdn5.rccaraction.com/wp-content/gallery/kyosho-ready-set-dmt-ve-r-4wd-monster-truck/30844b-3.png?5ee87f
http://cdn7.rccaraction.com/wp-content/gallery/kyosho-ready-set-dmt-ve-r-4wd-monster-truck/30844b-2.png?5ee87f
http://cdn5.rccaraction.com/wp-content/gallery/kyosho-ready-set-dmt-ve-r-4wd-monster-truck/30844b-1.png?5ee87f
Features:
  • Full Time 4WD – The full-time 4WD chassis incorporates all of Kyosho’s formidable resources and know-how in the development of this low center of gravity shaft-driven 3-differential drive train.
  • EZ Mesh – ORION VORTEX R10 brushless motor is pre-fitted on an aluminum die cast motor mount and allows the use of 3S LiPo batteries for incredible performance.
  • LiPo – Can be used with either a 7.4V-11.1V Lipo battery. Release the throttle and switch the power on to complete auto setup.
  • Interchangeable – Ball connected suspension features interchangeable suspension arms, front-rear knuckles and shock stays for optimal parts utilization and maintenance efficiency.
  • Double Wishbone Sus. – Double wishbone 4-wheel independent suspension with long span arms delivers excellent handling from paved to off-road surfaces.
  • High Grip Tires – High grip tires and the same wheels proven on the INFERNO ST-R allow you to dominate any running surface. The wheels are also compatible with a wide variety of after market tires.
  • Big Bore Shocks – Features heavy duty big bore oil shocks as standard. Takes even the harshest punishment for long periods without complaint and provides excellent damping power.
  • Pre Painted Body – Pre-painted so you can enjoy the action in true truck style without delay.
  • HD Ring & Pinion – Precision machine cut diff ring and pinion gears provides extra strength and durability.
  • Adjustable ESC – ESC settings can be adjusted with an optional digital setup box.
  • Multipoint Adjustments – Design features multi-point setting adjustments such as chassis height, camber, track width, front and rear toe-in etc.
  • Shaft Drive – The drive shafts run through the center of the chassis to give you a lower CG and optimum weight balance.
  • New Steering Layout – The DMT VE has a whole new steering layout which gives you greater response and much more steering angle.
  • Aluminum Motor Mount – Equipped with a silver aluminum motor mount to secure the 540 Size Orion BL
    Technical Data:
    Length: 485mm (19in)
    Width: 385mm (15.1in)
    Height: 212mm (8.3in)
    Wheelbase: 320mm (12.5in)
    Gear Ration: 16.34:1
    Weight: 2,780g
    Motor: KV2400 Vortex 10 Brushless
    Battery: 7.2 – 8.4volt NiMH or 7.4 – 11.1volt LiPO Battery Type with Deans Plug
    ESC: Vortex R10 Sport
    引用 Kenlcok 13-3-30 10:06
    哎···大脚只能上3S···
    引用 马环宇 13-3-29 13:31
    京商下坡路走的真是一步一个脚印越来越稳了
    引用 Lu°远 13-3-28 20:03
    车子没什么可说的。配件实在是贵死了,最恶心的还是这套遥控系统,距离比一般AM都近很多,实在是唉。。。
    引用 TIGER9901 13-3-28 19:17
    换了个动力而已,一样的东西。
    引用 wanghaiya888 13-3-28 15:59
    DRT的底盘,呵呵,京商没想到也玩这招,恶心。
    引用 阿阿道夫 13-3-28 14:56
    在大陆买KYOSHO的配件是在是费劲啊,而且配件价格相对来说贵的要死
    引用 zhangbin500 13-3-28 14:02
    这个车早就有了   价格在2200左右 就是没看见有人买
    引用 UUA800 13-3-28 13:32
    f哇 这个电车好漂车啊!
    多少钱?大脚车越多越好!
    引用 CX199207175419 13-3-28 12:36
    这个状态好看多了,就不知道是不是还采用的链条传动
    查看全部评论(9)
