Kyosho PLAZMA Lm Porsche 962C
13-4-18 01:02| 发布者: rcfans| 查看: 8160| 评论: 6
Kyosho 京商推出附带Prosche 962C车壳的PLAZMA Lm 1/12电动平路车。新车将以Kit形式出现,为了进一步提高加速性能和极速,Kyosho去除了车架上多余的零件并对一些零件进行了优化。包括车架等使用了强化纤维材料,大大增加强度。支持2cell锂电(直条)和主流无刷动力。除了性能提升,维护方便性让车手和玩家能够快速拆装和调整车子。相信这款产品是像真和速度兼备的竞赛级遥控车。
点击这里->进入Kyosho京商品牌专区参与互动
  • FRP (Fiber Reinforced Plastic) is used throughout the kit including the main chassis, delivering additional strength and just the right amount of rigidity with no added weight.
  • Race Focused – The overall design and specifications of the new Plazama LM is focused on giving you the best racing experience, that you have come to expect from Kyosho.
  • Red – Equipped with precision machined red anodized aluminum components, such as the motor mount, side dampers and front bulkhead supports.
  • King Pin – Features king pin strut type front suspension, providing you precise control over the camber, caster and track adjustments.
  • Balance Control – The center pivot and side link rear suspension provides balance and control of the roll and pitch direction.
  • Center Shock – The rear, center shock is equipped with a diaphragm that maintains constant volume managing the roll direction and resulting in rock-solid running performance.
  • The Standard – The Plazma LM features international standard sized rear axle and the height can be managed by simply replacing the axle mount. Standard size wheels and tires can be installed front and rear.
  • 2 Cell – Compatible with 2-cell LiPo’s (stick pack).
  • Interchangeable – The front suspension is interchangeable (*except knuckles) providing you maximum maintenance efficiency.
  • Coil Springs – Proven performance coil springs located front and rear of the chassis. Features adjustable spring rates, giving you the control.
  • Rear Diffuser System
  • Standard: The Plazma LM is compatible with all standard sized servos.
  • Foams: Pre-glued sponge tires are included as standard equipment.
  • Porsche 962C- The body is pre-painted so all you have to do is add the decals and accessories. The body details include front and rear light buckets for LED lights*(optional), door mirrors, wipers, antenna and air ducts.
  • Ball Differential
    引用 taoyan 13-4-29 18:23
    车壳是亮点……里面看起来像F1改过来一样……
    引用 lixianfei321 13-4-18 10:08
    真是彪啊。
    引用 shi995800 13-4-18 09:50
    看着更娱乐些
    引用 林四海 13-4-18 08:59
    秀峰你来看我的我知道哈哈
    引用 Lu°远 13-4-18 08:30
    这个壳子还真的是很漂亮啊
    引用 点燃过往 13-4-18 08:28
    查看全部评论(6)
