Reds R5T Team Edition 2 引擎
13-4-16 13:32| 发布者: rcfans| 查看: 3897| 评论: 1
Reds Racing推出Team Edition 2越野车用竞赛级引擎,基于数位顶尖车手已经在使用的R5T研发而成。新版Team Edition 2能够减少油耗同时提高性能,散热效能也有提高,意味着引擎能够在更苛刻环境下运行。换上了新款曲轴等组件,散热顶重心也变得更低,使用了Reds独有的低阻力强化RDC黑色尾盖和陶瓷轴承。相信TE2是一款性能卓越的竞赛级产品。
Specifications
Category: 1/8 off road
Displacement [cm^3]: 3,5
Bore [mm]: 16,2
Stroke [mm]: 16,9
Inlet ports: 5
Outlet ports: 1 + 2 boosters
Front ball bearing DixDexS [mm]: 7x19x6
Front ball bearing features: Swiss Made
Rear ball bearing DixDexS [mm]: 14×25,4×6
Rear ball bearing features: Swiss Made Ceramic
Carburetor diameter [mm]: 6,7
Carburetor setting: Long needle
Glow plug: turbo 4,5,6
Weight: 348grams
Cylinder system: ABC
Exhaust type: rear
Recommended pipe: EFRA 2069 / 2099 / 2104
Recommended fuel: 20-30% nitro, 11-12% oil
Break-in fuel: 12% oil
    引用 dfnb322 13-4-16 16:46
    为啥不标马力和转速!
