Schumacher Mi5 详细信息
13-4-19 00:13| 发布者: rcfans| 查看: 17940| 评论: 14
Features
  • New vertically mounted, ultra long top deck offers super linear flex characteristics.
  • New lightweight carbon fibre wishbones for optimum stiffness.
  • New simple pivot ball system for wishbone mounting and easy roll centre adjustment.
  • New single piece motor/layshaft mount, centrally mounted to the chassis for perfect flex control.
  • New simple 3 point mounted ball raced steering rack for super smooth linear steering.
  • New single piece, centrally mounted, alloy/cf CNC servo and steering mount, for maximum stiffness in the steering system, and minimal impact on chassis flex.
  • New micro 4 deg caster pivot gives super low centre of gravity and  super smooth ball raced steering action with optional 6° available.
    New below arm shock mounting gives a low centre of gravity shock whilst keeping the same shock travel.
  • New chassis mounted droop screws for decreased unsprung weight.
  • New Schumacher lightweight gear diff.
  • New ultra lightweight front spool.
  • New shape lightweight foam bumper and chassis mounted mouldings.
  • New anti roll bars in 0.1mm increments.
  • New optional servo saver.
  • New LiPo retention mouldings.
  • New ball joint design for 2.0mm hex drivers.
  • New ball cup design with adjustment hole.
  • New 2 piece shock cap, for easier shock build.
  • New precision matched shock springs.
  • Optional Mid Motor conversion available, for extra high agility handling.
  • Aerospace carbon fibre 2.5mm soft weave chassis and components throughout.
  • Extreme lightweight alloy transmission housings.
  • CNC alloy, 20 tooth layshaft pulley.
  • Single sided layshaft mounting with quick release layshaft design for ease of maintenance.
  • Stiff 3mm shock towers with optimised shock positions.
  • Carbon fibre upper link design with options to adjust roll centres.
  • Anti-roll bar mounts with precise vernier adjustment to minimise play.
  • “O” ring retained alloy wheel hexes.
  • Fully adjustable, suspension geometry, wheelbase, caster, camber, roll centre, ackerman, droop, anti-dive, anti-squat, front toe in/out, ride height and much more.
  • Efficient transmission with twin bando belts and precision CNC pulleys.
  • Alloy eccentric adjusters for optimum belt tension.
  • Quick release front and rear entry diffs to leave chassis structure intact when removing diffs for maintenance.
  • Ultra smooth nickel-teflon plated threaded alloy shock absorbers for extreme smoothness and durability.
  • Dedicated front & rear, reverse cup, high tensile steel, CVD driveshafts.
  • Differential and spool plastic insert “sliders”. Offer a lightweight, efficient driveshaft interface.
  • Speed secret parts available to fine tune to all track conditions.
  • Adjustable front steering hubs with optional carbon fibre parts.
  • Adjustable rear hub carriers with optional carbon fibre parts.
  • Black alloy M3 nuts.
  • Lightweight black alloy washers throughout.
  • Alloy front kingpins.
  • Front to rear, 3 position, cell LiPo adjustment for fine tuning weight distribution.
  • Quick release alloy layshaft fence for quick release diff and belt removal.
  • Top adjustable lightweight roll bar sockets and links.
12
    引用 吴DW 21-1-27 19:41
    中置电房?!
    引用 zwtnt168 13-4-20 07:09
    怎么都不用心研发好车呢?
    引用 法拉利599GTB 13-4-19 21:27
    滑块试转向 意味着环境差的场地对车子影响大了
    引用 凡阿特 13-4-19 19:13
    最后一张图是等长皮带?
    引用 千喜兽 13-4-19 16:54
    摆臂都他奶奶的是碳纤维板做的,不惜成本啊
    引用 butter123 13-4-19 11:26
    最牛B的设计是转向设计吧!
    引用 shi995800 13-4-19 10:29
    设计感很强裂
    引用 zippo23 13-4-19 10:14
    更换二楼改变马达座位置?
    引用 pal 13-4-19 09:19
    这重心,这重量。。操控一定不俗
    引用 sllzhlv37 13-4-19 08:36
    ab是用球头的么、、感觉这么奇怪的说、、大神们快去做厂车手做代理啊
    引用 zjssxx 13-4-19 08:34
    非常前卫的设计
    引用 pkqq123 13-4-19 06:48
    碳纤维A臂啊
    引用 NJ 13-4-19 03:52
    又得去开发新车了。。。
    引用 初次玩车 13-4-19 01:27
    有好多新奇的零件啊
    查看全部评论(14)
