Traxxas 推出 1/18 拉力遥控车LaTrax
13-7-2 12:31| 发布者: rcfans| 查看: 26159| 评论: 15
Traxxas推出全新1/18拉力遥控车,新车使用LaTrax品牌发布。出厂预先安装完成,一台高性能RTR(Ready-to-Race®)街车!LaTrax拉力车的定位是充满乐趣的产品,原车的电池和动力系统让车速达到27KM/h以上,如果选用升级的6cell电池,车速将突破32km/h。4WD传动、2.4GHz遥控、宽身车壳设计、12抓拉力轮圈、全天候防水电子设备让玩家能无惧任何天气和地形,随时随地玩车!Traxxas将LaTrax设计得更坚固,减少玩家对车子的维护频率,将更多时间投入到享受操控乐趣中。该产品将于本月中旬上市,多款原厂升级和改装件也将陆续上市。
关于LaTrax:LaTrax品牌创办自1974年,由Traxxas现任CEO父亲Jim Jenkins创立,LaTrax品牌旗下的产品以创新、高性能RTR为主,产品价格控制在200美元内,希望将遥控模型推广至普罗大众。
点击这里->进入Traxxas品牌专区参与互动
Traxxas厂方视频介绍:
美国RCCaraction视频介绍:
  • Fully assembled and Ready-To-Run
  • Tough, rally-inspired body design with cutting edge graphics
  • Pre-glued, low-profile slick tires mounted on white, 12-spoke rally wheels
  • Impact-absorbing foam front bumper
  • Adjustable-height body mounts
  • Waterproof, All-Weather Electronic Speed Control
    • Innovative all-weather design
    • Fully-proportional forward, reverse, and braking control
    • Programmable with three drive profiles:
    • Sport Mode – Forward / Brake / Reverse
    • Race Mode – Forward / Brake
    • Training Mode – 50% Forward / Brake / 50% Reverse
    • EZ-Set® push-button setup
    • Multi-color LED
    • Thermal shutdown protection
    • Efficient, low-loss MOSFET design
    • Smooth, high-frequency operation
  • Powerful 370 brushed motor
  • Includes LaTrax 6.0V 5-cell NiMH battery pack and charger
  • High-torque waterproof sub-micro steering servo
  • Weather-sealed receiver box
  • Full-time 4WD
  • Front and rear gear differentials
  • Front C-hub design with universal driveshafts
  • Rear axle carrier with universal driveshafts
  • Coil-over shocks with variable mounting positions
  • 4-wheel fully independent suspension
  • Fiber-composite chassis
  • Speed control and receiver are securely fastened to chassis
  • Quick-release battery hold-down for fast battery pack changes
  • 2.4GHz Transmitter
    • 2-channel transmitter
    • Servo reversing
    • Electronic steering trim controls
    • Low battery indicator
    • Internal antenna
    • Distinctive, ergonomic, contour grip
  • Award-winning Traxxas support and parts availability
12下一页
    引用 wdkzdom 13-7-3 13:26
    卖点在壳上,如果出几款仿真车壳,应该不错
    引用 askrun 13-7-3 10:30
    这车太玩具了
    引用 一缕络腮胡 13-7-3 02:28
    还不错,看价格吧
    引用 asstan_525 13-7-2 21:25
    很玩具。。。。。。。
    引用 小IH菜 13-7-2 20:29
    我感脚着就这车壳就太没感脚了!!!!!
    哦  刚才没看第二页  避震是一大亮点!!!
    引用 zwtnt168 13-7-2 20:20
    尼玛,这叫拉力车?地盘那么低,平跑还差不多!
    引用 聪哥 13-7-2 18:48
    首先外观就够失败了
    引用 qq395422218 13-7-2 18:32
    500元可以考虑下
    引用 shi995800 13-7-2 16:57
    这车的螺丝和避震~~~
    引用 TIGER9901 13-7-2 16:46
    接受居然是台湾的
    引用 bsj959 13-7-2 15:41
    估计很贵
    引用 光明三藏 13-7-2 14:50
    ............................ 迷你四驱车啊....................
    引用 慕东 13-7-2 14:02
    看着好像还可以...........
    引用 马环宇 13-7-2 13:09
    毫无性价比,感觉不如ae的18仔
    引用 芝尚546764159 13-7-2 12:58
    LA................
    查看全部评论(15)
