Schumacher Cougar KF 2WD 越野车
13-11-6 23:18| 发布者: rcfans| 查看: 12052| 评论: 10
特性:
  • Front & Rear nut guards.  Look Cool and Protect your car and the track from damage.
  • Central motor layout offers superb cornering on high grip tracks.
  • Adjustable internal ratio to rotate the motor in the same direction as the wheels. Gives excellent jump control
  • Stronger front steering hub, with fine ‘Kwik Klip’ Adjustment.
  • Hi-Tensile, revised style silver turnbuckles.
  • 12mm Hex Wheels with clean look and industry standard offset.
  • Moulded side pods for superb dirt protection.  Fantastic dirt seal with no handling compromise.
  • 2.5mm aerospace grade lightweight carbon fibre chassis & top deck.
  • Smooth twin pad vented slipper with easy access adjustment.
  • Single belt transmission with efficient low tension belts running on large CNC machined pulleys, gives super smooth, quick acceleration.
  • Optimum forward weight distribution with saddle packs or optional ‘Shorty’ layout.
  • Strong, rigid 4mm aero space carbon fibre shock brackets.
  • Stronger front bulkhead and bottom plate.
  • PTFE coated shock bodies - Hard, with a super smooth shock action.
  • Optional steel front skid plate - Reduces wear.
  • Pro spec 13mm big bore shocks with titanium nitride shafts, CNC machined 3 hole pistons with recessed ‘e’clips, threaded collars, twin O ring sealing and diaphragm volume compensation.
  • Long front wishbones - Improved corner speed and super safe handling.
  • Unique motor clamp mount to fine tune weight distribution.
  • Excellent centre line balance.
  • Fully optimised suspension geometry - Fast, consistent handling.
  • Maximum dimension wing. Superb airflow control and max downforce.  Enhances the new AirFlo Cab package.  New AirFlo Cab body shell for improved looks and handling.
  • Black anodised components for the aggressive stealth look.
  • Horizontally split transmission housings for easy diff access and maintenance.
  • Belt adjustment for correct tension.
  • Gear Differential with hardened steel gears and super hard outputs.  Excellent Diff Life!  Optional ball diff available.
  • CVA style driveshafts - Increased drive.
  • 27 Rubber sealed, super precision ball bearings throughout.
http://www.racing-cars.com/pp/Car_Showroom/images/CougarKF_rtq_nb_1000.jpg
http://www.racing-cars.com/pp/Car_Showroom/images/CougarKF_side_1000.jpg
12
    引用 zch 13-11-8 14:12
    现在玩后驱都要备齐三辆啊,后置,后中置,中置对应低抓,高抓,超高抓的场地啊
    引用 shi995800 13-11-7 23:42
    看着真心不错~~~
    引用 天亮了888 13-11-7 21:38
    哇去....帅!上市入手
    引用 kzk.adu 13-11-7 19:51
    太帅了
    引用 ss_aa 13-11-7 13:56
    这就是我为啥喜欢舒马赫的原因,哈哈哈哈哈~赞
    引用 zonda113 13-11-7 10:42
    竟然是皮帶,看著好帥
    引用 ROVERED 13-11-7 08:22
    想起那台,是不是换个套件又能变四驱。。。
    引用 Jason.An 13-11-7 01:35
    还不错呦……
    引用 GAMOlover2 13-11-7 00:45
    造型不错,.........
    引用 bgb 13-11-6 23:34
    分体锂电
    查看全部评论(10)
