Traxxas 2.4 ghz 遥控器
查看: 1000|回复: 1| [复制链接]
用户可以通过 高级 Fans 发消息
发表于 20-6-2 21:50:12 |显示全部楼层 来自: 美国
大神知道怎样设定油门反方向吗
richmond 金牌 Fans 发消息
发表于 20-6-3 02:23:20 |显示全部楼层 来自: 中国广东广州
TQ型号
Steering reversing procedure:
1. Power on the transmitter. Press and hold the SET button on the transmitter for two seconds. The status LED will flash green.
2. Turn and hold the steering wheel to the full left or full right position (it does not matter which position you choose).
3. While holding the steering wheel in position, press the SET button to reverse the channel.
4. The channel is now reversed. Confirm correct servo operation before running your model.
