发表于 15-6-9 18:19:28 |显示全部楼层 来自: 中国广东深圳
XQ-POWER SERVO
XQ-S4330D :一款專為車打造的一款高端數碼舵機,標準尺寸外觀,
                      全金屬CNC外殼,標準電壓4.8-72V電壓,30KG超大扭力數碼舵機
具體參數如下
Name:6V30kg-cm Digital Servo;
Size :A:40.2mm B:20.1mm C:38.8mm D:48.0mm E:10mm;
Weight:65g ±0.2(2.29oz);
Gear type:Titanium Gear;
Speed:0.18sec/60o at (6.0V)
      0.20sec/60o at (4.8V)
Torque:(416.6 oz-in)30kg.cm.at(6.0V)
       (374.9 oz-in)27kg.cm.at(4.8V)
  Features:Waterproof,tamper-proof servo wire, All Aluminium CNC case,
easy to eliminate heat and corrosion;Adopt high quality coreless motor.
舵機圖片:
