本帖最后由 SERPENT蛇仔官方 于 16-1-13 12:59 编辑 Serpent 蛇仔宣佈推出全新 SRX4 專用限滑套件 为更好应对低抓著力路面, Serpent 推出了附帶压力軸承的限滑系統以供 SRX4 的车主選用 "Serpent introduce the thrust slipper as set for the belt-driven Spyder SRX4 buggy , with a clear online pdf manual to show the assembly. The 3-pad slipper assembly allows you to smoothen the power distribution between front and rear, which is especially needed on the more slippery surfaces. On carpet/astro you can also try it ofcourse." #500483 以下为組裝說明書: |
