Serpent 蛇仔发佈 977-Evo 系列的升級件: 加硬离合弹簧及二樓板支撑桿: 903647 加硬离合弹簧 903647 Centax spring x-hard Serpent introduces this extra hard Centax spring to be used in Serpent Viper and all previous Serpent 1/8 scale cars and many other 1/8 cars. This extra hard spring is precision made and flat grinded for even performance. Serpent designer Ron Ton invented the Centax clutch in 1992, and its has become the clutch that all brands in some way started using after too. Serpent continuously tries to improve this original concept. 903653 二樓板支撑桿 903653 Stiffener set 977 Viper Serpent introduces this chassis stiffener to be used on the Viper 977 cars. The stiffener will reduce the chassis flex around the engine area and will help to smoothen the braking action. The alu brace as shown replaces the original bottom one to have a mounting point, and the other side mounts to the 2-speed shaft bracket v2 version, which is already included in the latest Viper 977-evo kits. The springsteel trackrod combined with ball and balljoints from the strong connection and is easily removed for maintenance or cleaning work on the car. 以下为組装說明書: |
