RC Atomic BZ3 1/28 迷你遥控车
19-6-19 00:25| 发布者: rcfans| 查看: 8042| 评论: 4
RC Atomic推出新款迷你遥控车(蚊车), BZ3 1/28 4WD。90%新零件,竞赛级产品,采用全新的前悬挂摇臂,提高直线行走稳定性,可调0度至12度的caster角度,十足电房设定。
整合了舵机保护器的单片式曲柄转向结构和全新尾悬挂骨架,创造了更佳的悬挂几何设定。全新的UTS尾T-arm系统,可以增加车尾的刚性,保障抓地力。超低重心底板设计,新的珠差、波箱、避震架和低重心马达座,专业玩家喜爱的ARS系统继续保留,让BZ3新车全面提升性能。无论是地毯赛道、RCP还是EVA赛道,Atomic这台BZ3都能快速适应,弯道表现更出色。
The rear suspension system is the main innovation part of BZ3. It can convert into 3 forms to suit all kinds of track conditions:
(1) CLS – Camber Link System (like BZ2017, suitable for carpet, low to medium traction)
(2) UTS – Upper T-Arm System. (new in BZ3, suitable for RCP or EVA tracks, those high traction condition)
(3) ARS – Active Rear-Toe system, (like BZ 2016, for experts who knows set up very well)
    引用 itolfndc 19-6-23 19:52
    漂亮
    引用 omo 19-6-19 16:22
    好看
    引用 x496083245 19-6-19 10:49
    螺丝换成6角就好了,希望精度能有提升
    引用 志鹏 19-6-19 00:38
    t4
