HPI Flux 无刷系统
08-4-21 08:42| 发布者: jovi| 查看: 2979| 评论: 1
HPI Racing品牌推出的Flux无刷系统,在马力及效率上都表现不错,它有大型的散热片,即插即用的设计。配合Flux Warp 无刷马达。
Flux Motiv Brushless ESC Features:
- 6-8 cell NiMH / NiCd or 2 Cell Lithium Polymer (with 5700Kv Motor)
- 6-12 cell NiMH / NiCd or 2-3 Cell Lithium Polymer (with 4600Kv and below Motor)
- 70A* Continuous / 380A burst current
- Ultra low resistance (.0007 ohms / phase)
- Sensorless technology eliminates additional sensor wiring and complexity
- Lithium Compatible**. Programmable Lithium under-voltage cutoff protects delicate Lithium packs from over-discharge
*25C temperature, 5mph air flow through heat sink minimum. Burst current: < 2 seconds duration, 1% Duty cycle
**ESC must be programmed for Lithium cutoff when using Lithium batteries.
相关阅读
    引用 gfeili 08-9-2 16:22
    这套多少钱,有详细说明吗?
