Team Orion Carbon FLX 锂电
11-4-27 23:50| 发布者: admin| 查看: 3983| 评论: 11
Team Orion给HPI Savage Flux无刷电动大脚推出专用锂电,完美配合Savage车架设计,无需任何改装即可安装在Flux车架上。性能方面支持45C放电,有2S和3S版本,Deans接头,有4000mAh,6000mAh,8000mAh 2S和4000mAh和6000mAh 3S
The Carbon FLX LiPo batteries are specifically designed for the Savage Flux. Thanks to the custom case design, capacity and performance are maximized.
Features:
    - Carbon Look Special Hard Case
    - Latest LiPo Technology Factory Fresh Cells
    - Maximized Capacity
    - Up to 45C Discharge Rate
    - 2S and 3S Versions
    - For HPI Savage Flux Cars - Ultra Flexible High Quality Silicone Cables
    - Deans Connector fits HPI Cars without modifications
    - Integrated Balancing System (JST-XH Adapter Cable Included)
    - Stylish Product and Packaging Design
    - Dimensions: 196.0x51.6x28.9mm
With the dimensions of 196.0x51.6x28.9mm and the unique, rounded form of the hard case, the battery fills the complete battery compartment of HPI's Savage Flux. In battery technology volume means more capacity and/or more voltage. Up to 8000mAh in the 2S and 6000mAh in the 3S battery deliver a maximum of run time and power output. Of course the battery is equipped with original Deans plugs for the direct connection with the HPI electronics. Ultra flexible Silicone cables are standard for Team Orion batteries.
The Carbon FLX battery comes with the Integrated Balancing System. Thanks to this system the balancing wire can be removed for easier installation inside the car. An JST-XH adapter for balancing is included.
欢迎进入RCFans大脚车讨论区参与讨论
http://www.rcfans.com/bbs/forum.php?mod=forumdisplay&fid=9
Source: Team Orion [teamorion.com]
    引用 vbbsss 11-4-29 21:49
    我擦,这电池一对6000的3S估计能搞掉半辆二手HP
    引用 shenmirenandy 11-4-29 17:46
    太牛叉了,米也太牛叉了
    引用 wddy 11-4-29 08:24
    估计很多米
    引用 shb99 11-4-29 02:19
    百毒不侵, 无米路过
    引用 三氧化钼 11-4-28 21:27
    太它妈,给力。
    引用 happyy2002 11-4-28 14:18
    毒物啊``!1没米。百毒不侵···
    引用 THIBAULT 11-4-28 13:01
    估计价格也很牛啊
    引用 陪你,看日出 11-4-28 13:01
    额,,某些人的车车要残废了
    引用 LeoChen 11-4-28 10:24
    期待已久的东东啊 哈哈  下次去德国找找看
    引用 fqljldh 11-4-28 09:01
    8000阿 ...厉害.
    引用 yuhanbaby 11-4-28 07:44
    这个有点牛叉的。
    查看全部评论(11)
