Much More Impact 5600mAh锂电
10-3-31 05:04| 发布者: admin| 查看: 1932| 评论: 0
muchmoreimpact5600Much More 推出新款锂电 Impact 5600mAh, 35C ,14.8V ,硬壳,专为1/8无刷电动越野或平路车设计!详细性能参数在本文内。IMPACT 5600 35C 14.8V [MLI-IBH5600] Features -Provides the excellence of the quality. -Shape is straight as a Sub-C cell battery. -Suitable for 1/8th Off-road and On-road. -Hard case increases safety of the battery.  Specs -Size : 164 x 52x 52mm -Weight : 669g -Balancing plug : JST-XH -Connector : Ultra 2P -Wire : 12 AWG -Cubic capacity : 5600mAh -Voltage Input : 14.8V - 4S -C-rate : 35C
