XRAY XB808 头防倾杆2.3mm和2.5mm
11-1-25 23:23| 发布者: admin| 查看: 3384| 评论: 0
Xray为XB808越野车推出头防倾杆,两种不同硬度。
#352483 XB808 Front Anti-Roll Bar 2.3mm
#352485 XB808 Front Anti-Roll Bar 2.5mm
• front anti-roll bar
• 2.3mm & 2.5mm thick
• laser-engraved lines for easy identification
• manufactured in-house
• premium heat-treated spring steel wire
Anti-roll bar wires of different thickness are optionally available for fine-tuning the setup of your XB808. XRAY anti-roll bars are manually manufactured in-house from premium heat-treated spring steel wire using precision bending machines that ensure equal side angles. Manually measured, selected, and straightened to eliminate all tweak.
