LRP Vector X-12L短途卡车550马达
11-1-27 17:58| 发布者: admin| 查看: 2171| 评论: 1
LRP为短途卡车(SC)推出了Vector X-12无刷马达,这是一颗550级别的竞赛级无刷马达,专门为竞赛级四驱短途卡车开发设计!
Vector X-12L Features:
- 550 Size – 75% longer magnet and stack for high power and torque
- HDS Technology – Optimized winding for power-hungry 4×4 Short Course trucks
- PreciSensor System – Revolutionary precise sensor positioning for great power, efficiency, and throttle feel
- 5mm output shaft
- Re-buildable
- Easy solder tabs
Source: Associated [rc10.com] & Redrc.net
    引用 SIKANNIYA 11-1-29 23:57
    这个牛X  给拖头换上 不知道啥感觉  估计3档 破百没问题
