Protek R/C Prodigy推出610 和610 Duo两款充电器。610 DUO提供两组独立输出充电,带温控检测,还有一个5V 1000mA USB输出接口,PC Link接口让玩家实时监测充电状态,而610充电器带一组输出,功能也较610 DUO简单。详细介绍可看本文的原厂介绍资料。 ![http://www.redrc.net/wp-content/uploads/2011/03/Protek610Duo.jpg](http://www.redrc.net/wp-content/uploads/2011/03/Protek610Duo.jpg)
610 duo features two independent channels,
each capable of supplying 200W and monitoring the battery’s condition
with its own internal balance port and temperature sensor port so you
can charge your batteries quickly and safely. A 5V, 1000mA USB port
allows you to charge any USB device conveniently at your work space,
while the PC Link port gives you the option to monitor and log overall
pack voltage, temperature, current and total capacity. Additionally, an
intuitive touch-sensitive navigation panel will allow you to easily
make your way through the charger menus without worrying about buttons
malfunctioning due to debris, and the blue backlit LCD display with
white characters offers clear visibility in any environment. The Prodigy
610 differs in that it only features one channel capable of supplying
200W, which apart from the form of the device itself, is essentially
the same charger.
The Prodigy 610 Duo can handle LiPo, LiFe, and Li-Ion batteries up to
6S; up to 18-cell NiCd and NiMH batteries per channel; and 2-24V
lead-acid batteries. With the ability to fast charge, balance charge,
and storage charge lithium cells, you can easily tailor the charge
process to suit your needs, while individual cell voltage can be
monitored during balance mode charging, allowing you to identify an
imbalance in the cells and spot a weak cell before it becomes a problem.
Other features include a dual-fan cooling system that utilizes a
push-pull design that will keep the charger cool, even when working at
maximum capacity.
Prodigy 610 Duo features:
- Optimized Operating Software: An optimized “Auto” function controls
the charge rate during the charging and discharging process. This will
help to prevent damage due to user error. If there is a malfunction,
the circuit will be disconnected automatically and an alarm will sound.
All operating modes are controlled through a two-way communication
process between the charger and the battery in order to maintain maximum
safety, and all settings can be configured by the user.
- Internal Lithium Battery Balancer: Each channel features an individual
cell voltage balancer. An external balancer is not required for
balance charging.
- Individual Cell Discharge Balancing: When discharging, each cell is
monitored and balanced individually. If the voltage of any cell is
abnormal, an error message will be displayed and the process will be
terminated.
- Lithium Battery Adaptability: Compatible with the three most common Lithium battery types: LiPo, Li-ion, and LiFe.
- Multiple Lithium Battery Charge Modes: Programming allows Fast Charge,
Balance Charge or Storage Charge Modes for LiPo, Li-ion, and LiFe
batteries.
o “Fast” Charge Mode: Reduces charging time, but does not balance the
cells and charges the battery to approximately 90% capacity.
o “Balance” Charge Mode: Monitors individual cell voltage, keeps the
cells within an acceptable voltage range and charges the pack to peak
capacity.
o “Storage” Charge Mode: Used for long-term battery storage. Adjusts the
voltage level so the battery will not be damaged during storage.
- Maximum Safety Through Delta-Peak Technology: The automatic charge
termination program uses Delta-Peak voltage detection. When the
battery’s voltage exceeds the threshold, the process will be terminated
automatically.
- Automatic Charging Current Limit: The upper limit of the charge
current can be set for charging NiCd or NiMH batteries. This is useful
for NiMH batteries with low resistance and capacity in the ‘AUTO’
charging mode.
- Temperature Threshold: The batteries internal chemical reaction can
cause the temperature of the battery to rise during charging. If the
temperature limit is reached, the charging process will be terminated.
This function is only available when using the temperature probe and its
parameters are user-specified.
- Processing Time Limit: The user can set the maximum charging time. If
the charging time exceeds the limit, the process will be terminated
automatically.
- 10 User Presets: Customize 10 individual presets, each with different
parameters set for a particular battery type. This allows the user to
“call up” the settings for a particular batterywithout additional
programming needed.
- Cyclic Charging/Discharging: Batteries can be set Charge/Discharge or Discharge/Charge for up to 5 cycles.
Specifications:
Operating Voltage Range: 11-18 Volts DC
Max Charge Power: 2×200 watts
Max Discharge Power: 2×25 watts
Charge Current Range: 0.1-10.0A
Discharge Current Range: 0.1-5.0A
Current Drain for Balancing LiPo/Li-ion/LiFe: 200mA/cell
LiPo/Li-ion/LiFe Cell Count: 1-6 cells
NiCd/NiMH Cell Count: 1-18 cells
Pb Battery Voltage: 2V-24V
Dimension: 200×135×57mm ![http://www.redrc.net/wp-content/uploads/2011/03/Protek610.jpg](http://www.redrc.net/wp-content/uploads/2011/03/Protek610.jpg)
The Prodigy 610 can handle LiPo, LiFe, and Li-ion batteries up to 6S;
up to 18-cell NiCd and NiMH batteries; and 2-24V lead-acid batteries.
With the ability to fast charge, balance charge, and storage charge
lithium cells, you can easily tailor the charge process to suit your
needs, while individual cell voltage can be monitored during balance
mode charging so you can identify an imbalance in the cells and spot a
weak cell before it becomes a problem. Other features include a single
fan cooling system that will keep the charger cool, even when working at
maximum capacity.
Prodigy 610 Features:
All operating modes are controlled through a two way communication
safety and all settings can be configured by the user.
- Internal Lithium Battery Balancer: An external balancer is not required for balance charging.
terminated.
- Lithium Battery Adaptability: Compatible with the three most common Lithium battery types: Li-ion, LiPo and LiFe.
Balance Charge or Storage Charge Modes for LiPo, LiFe, and Li-ion
batteries.
capacity.
o “Storage” Charge Mode: Use for long-term battery storage. Adjusts the
automatically.
charging mode.
the charging time exceeds the limit the process will be terminated
automatically when you set the maximum time for the charging mode.
recall the settings for a particular battery with no additional
programming needed.
Specifications:
Operating Voltage Range: 11-18V DC
Max Charge Power: 200W
Max Discharge Power: 25W
NiCd/NiMH Battery Cell Count: 1-18 cells
Pb Battery Voltage: 2V-24V (1-10 cells)
Net Weight: 607g
Dimensions (mm): 150×116.5×53
Source: Protek R/C [amainhobbies.com] |
