ProTek推出Prodigy 620 Duo充电器
12-5-1 22:23| 发布者: rcfans| 查看: 4107| 评论: 1
ProTek推出Prodigy 620 Duo充电器,带两组独立的400W输出,每组充电输出均有独立的控制面板。使用蓝色背光LCD,双风扇散热设计。带有平衡接口和温控感应接口,可对LiPo, LiFe和Li-Ion电池充电,最高支持6S。支持最高15颗NiCd或NiMH电池充电,还可以对最高20V的蓄电池进行充电。Prodigy 620 Duo充电器内置快充(fast charge)、平衡充(balance charge)和存储充(storage charge)不同模式为锂电服务,另外还具备单颗电池检测,能够找出问题电池。
Specifications:
Operating Voltage Range: 12-18 Volts DC
Max Charge Power: 2x400 watts
Max Discharge Power: 2x25 watts
Charge Current Range: 0.1-20.0A
Discharge Current Range: 0.1-5.0A
Current Drain for Balancing LiPo/Li-ion/LiFe: 300mA/cell
LiPo/Li-ion/LiFe Cell Count: 1-6 cells
NiCd/NiMH Cell Count: 1-15 cells
Pb Battery Voltage: 2V-20V
Dimension: 200x140x55mm
Includes:
  • (1) Prodigy 620 DUO Charger
  • (2) JST-XH Balancing Adapter
  • (1) Alligator Clip Charging Cable
  • (2) 18AWG Wire Charging Cable
  • (2) Plug-in Battery Clamps
    引用 chopin8674 12-5-1 22:58
    这个看着真心情 适合蓝色系车啊
