STRC Slash 4×4 GT-8/rally cross转换套件
11-6-26 01:36| 发布者: admin| 查看: 5821| 评论: 11
我们之前有报道过STRC将推出Slash短卡用的转换套件,让Traxxas Slash 4×4 转换成1/8 拉力遥控车。现在STRC正式公布了这套升级转换套件的详细资料,转换后的Slahs非常适合在停车场或跑街,转换后的车重只有 2440g,相对于部分使用1/8越野车转换成拉力车的产品重量轻了很多。套件包括铝制防撞杆、波箱座、17mm轮圈接合器等零件,提供四种颜色供玩家选择。
Tired of bashing your Slash 4x4 as a short course truck and want to try something new?  How about turning it into a land missile?  Or go rally style and go fast and low across asphalt and dirt? Our Slash 4x4 GT-8/Rally Cross conversion kit gives a new and exciting way to enjoy your Slash 4x4.  In GT-8 configuration, the light weight of the Slash 4x4 with high-grip on-road tires will launch this now on-road ready car with incredible acceleration and hit high top speed even with just a 2S battery.  Throw in a 3S….then you better make sure you find yourself a big enough parking lot for your new land missile.
This conversion includes:
CNC Machined Aluminum HD Front lower bumper
Thick 3mm Graphite Upper Bumper hold down plate
CNC machined Aluminum bumper posts (3 pcs)
CNC Machined Aluminum Front lower hinge-pin block
CNC Machined Aluminum Front Bumper/Gearbox brace
CNC Machined Aluminum Rear Lower hinge-pin block
CNC Machined Aluminum 17mm Hex Adapters (4 pcs)
CNC Machined Aluminum 17mm Hex adapter hold-down nut (4 pcs)
CNC Machined Aluminum 17mm Wheel Nut (4 pcs)
All screws and hardware necessary to install.
(will require 1/8th GT Tires and Body and foam front bumper to complete)
The conversion kit is easy to install and it keeps the general layout of the slash and retain some ground clearance for those that wants to go rally with the conversion.  The front bumper keeps the slight front kick-up so in rally configuration it does not dig into the dirt from small jump landings. Compare to the 1/8th scale buggy converted GT-8 out there, our Slash GT-8 have a huge power-to-weight ratio advantage.  On average a GT-8 with 4S weigh in at 8lbs 2 oz, while the Slash GT-8 comes in at a mere 5lbs 2 ozs with a 2S, and with a 3S, it is only at 5lbs 6 ozs.
Source: STRC [teamstrc.com]
    引用 13656665002 11-6-28 10:21
    这个给力啊
    引用 jeisa 11-6-28 10:13
    。。。传说中的1比8电房??
    引用 鸡蛋炒饭1 11-6-27 11:34
    轮胎和前防撞是KEYSHO 1:8GT 的?很像很像。。。。
    引用 chengning0516 11-6-27 07:43
    避震怎么办?短卡的行程那么大,变平跑轮子会蹭车壳啊
    引用 okenmai 11-6-27 06:31
    配什么车壳是问题~~~
    引用 groovyice 11-6-26 12:27
    车壳怎么配?
    引用 justin1223 11-6-26 12:03
    这套件$89.99,将近¥600!
    引用 zhenglanlin 11-6-26 12:01
    史上最耐操的平跑+1
    引用 boxer_engine 11-6-26 11:44
    史上最耐操平跑?
    引用 SKYHY 11-6-26 11:12
    我擦一车多玩.
    引用 kimzhong 11-6-26 09:45
    哪里有得买才行啊
    查看全部评论(11)
