RTR SAVAGE XS FLUX发布
11-7-9 01:08| 发布者: admin| 查看: 5300| 评论: 0
广受万千玩家喜爱的Savage Flux推出迷你版,让你拥有不同尺寸的乐趣选择!它所搭载的电调拥有难以置信的疯狂动力,实现了充满压迫感的行走速度。底盘依旧传承了Savage家族 特有的垂直侧板,具有无可比拟的强度,同时不失真实感和底盘通过性。同时不要忘了这是一款可以塞进背包的Savage!拥有普通 Savage三分之二大小的尺寸,你可以轻松带它去任何地方,玩车随时随地!
Savage XS Flux依旧以强度作为架构设计的主旨,全金属传动可以承受巨大的跳跃和超过100KM的时速,四驱传动确保在任何越野或公路场地都具有良好的稳定性。
Savage XS Flux原厂组装完成,包含2.4GHz遥控器和Flux无刷动力系统。只需装上2S或3S电池即可玩耍!
Savage XS Flux Features:
  • TF-40/RF-40 2.4Ghz radio
  • SF10W waterproof servo
  • Waterproof receiver box
  • Vapor Pro waterproof brushless ESC
  • Vektor 4000Kv 1410 4 Pole brushless motor with cooling fan
  • Fits standard size 1/10th scale electronics
  • Silicone oil filled shocks with threaded bodies
  • All-metal bulletproof drivetrain
  • 2.2″ wheels and tires (can use most 1/10th scale truck wheels and tires)
  • Shock towers have multiple shock mounting positions (2)
  • Quick access to the front or rear differential by removing just 4 screws
  • Cam type servo saver
  • Spacious battery box w/locking battery box door
  • All socket head hardware
  • Dual pad slipper clutch
  • Full set of ball bearings
  • Aluminum motor plate with 4 motor mounting positions
  • Aluminum hex hubs
  • TVP (Twin Vertical Plate) chassis
  • Integrated chassis carry handle
  • Tough 4-gear differentials
  • Aluminum front and rear suspension braces
  • Stainless steel bulkhead lower plates
  • Front and rear skid plate bumpers
Specifications:
Length 360mm
Width 280mm
Wheelbase 225mm
全新的Savage XS Flux – 史上最快最劲的MINI大脚车.
RTR SAVAGE XS FLUX发布已经更新至官网敬请查看
http://www.hpiracing.net.cn/products.asp?id=534
本文内容由 HPIRacing 提供
