LRP Pulsar Touch 固件升级
11-8-4 23:28| 发布者: admin| 查看: 5010| 评论: 1
LRP Pulsar Touch充电器有最新固件供玩家升级。固件下载地址 http://www.teamassociated.com/lrp/
The download (zip file) includes:
  • The new v1.46 Pulsar Touch Firmware (PulsarTouch_v1.46.bin)
Changes of the new Firmware v1.46 include:
  • Revised adjustable “Charge Volt” settings for LiPo’s-now from 4.00 to 4.25V/C in 0.01V steps
  • Step-charging NiMH’s is now possible with no temperature probe connected
  • Improved hall-sensor check function
  • Small improvements to touch screen usage fixed a small bug with the delay timers in cycle function
Source : Team Associated
    引用 03591 12-12-20 20:17
    有什么用?
