Team Associated SC10 4×4 RTR
11-8-7 00:14| 发布者: admin| 查看: 6240| 评论: 15
Team Associated公布了SC10 4x4 Ready-To-Run(RTR) 短卡的资料。RTR版本的SC10 4X4使用了密封设备箱,Reedy 550 SL无刷马达、防水XP SC700电子变速器,XP-3SS 2.4GZh 三通道遥控器,S2008MG大扭力金属齿轮舵机,三款厂家喷涂完成的车壳(Lucas Oil, Pro Comp 和Rockstar/Makita)。预计这款产品在9月上市。
Features:
- XP3-SS 2.4GHz 3-channel radio system with S2008MG high- torque, metal-gear steering servo
- Water-resistant, high-power, LiPo-ready XP SC700 brushless speed control with heat sink fan and Deans Ultra Plug battery connector
- Reedy 550-SL 3500kV 4-pole brushless motor
- Water-resistant enclosed receiver box
- Unique dual gearbox drive train coupled together with a 5mm
heavy duty belt system with external tension adjustment
- 32-pitch front and rear gearboxes with sealed fluid-filled
differentials
- Decoupled center slipper clutch allows for front and rear wheel
drive to slip independently, resulting in more traction and stability
on bumpy track conditions
- CVAs with captured drive pins and heavy duty 6mm alloy axles
- 12mm hex drive KMC replica wheels front and rear with
aggressive short-course racing tires.
- Officially licensed replica championship short-course racing
body
- 13mm blue aluminum big-bore threaded shocks with low-
friction X-ring seals
- Composite modular tub chassis with low-CG and “low polar
moment” design
- Removable ESC tray for easy clean-up and maintenance
- Ball-bearing steering system with adjustable steering stops
- All-metric hardware and ball bearings throughout
    引用 8deepwater 11-8-9 13:48
    难道又要入一辆短卡!太心动了!
    引用 玩转三界 11-8-8 13:40
    售价3300左右  网上好像有卖了
    引用 abinggebln 11-8-7 21:26
    MD 攒钱
    引用 ANHX23 11-8-7 20:42
    黑色的一直很喜欢啊~九月又能买新车了~
    引用 zhenglanlin 11-8-7 17:59
    要是和死老鼠一样耐操就好了
    引用 阿阿道夫 11-8-7 17:35
    9月份出,为什么有人就能买到呢?
    引用 peacedence 11-8-7 17:05
    RTR!!!
    引用 邦德座驾 11-8-7 16:22
    陈启聪: 3000块左右就会买。。。。O(∩_∩)O~
    3k多点听说
    引用 陈启聪 11-8-7 15:42
    引用 邦德座驾 11-8-7 13:29
    绝对的好车,谁玩谁知道。再加上防倾杆,操控更加自信。
    引用 luofei 11-8-7 10:27
    就等9月份入手这个了啊 ...
    引用 鸡子 11-8-7 10:01
    不知道几钱啊
    引用 zwr1026 11-8-7 09:22
    等公布售价
    引用 speederhe 11-8-7 08:16
    白壳好看
    引用 shi995800 11-8-7 00:15
    终于出RTR了
    查看全部评论(15)
