S-Workz SST工具系列
11-8-26 22:10| 发布者: admin| 查看: 3495| 评论: 4
S-Workz推出新款SST工具系列。 轻量化的手柄、高精度的批头。
Hex wrenches come in 1.5mm to 2.5mm, with the 2.0mm & 2.5mm also available in ball versions. There is also a flat head screwdriver, a 4.0mm & 6.0mm Philips driver, a 5.5mm & 7.0mm socket driver as well as a spring/caster clip hook tool. Source:
    引用 liyingxia 11-8-31 15:04
    挺好看的~~~
    引用 xty000000 11-8-28 18:43
    EDS用着蛮好!
    引用 【加勒比海带】 11-8-27 11:03
    难看~~~两个字~价格还贵~直接上HUDY了
    引用 bnyzd 11-8-26 23:37
    比HUDY还贵。。。。难道比HUDY还好?
