Xray给自家的RX8 1/8平路车推出可调式尾防倾杆,让玩家可快速对防倾杆的硬度进行调整而无需更换任何零件。
![](http://image.rcfans.com/portal/201108/31/2339152jdkvcm5obsgzgvk.jpg)
#343401 Rear Adjustable Anti-Roll Bar – Set • Adjustable rear anti-roll bar set • quickly & easily adjust rear stiffness • beautifully CNC-machined roll bar body made from premium Swiss 7075 T6 • anti-roll bar blades machined and precision hand ground from world’s most exclusive Hudy Spring Steel™ • specially hardened to provide extra long life and high strength • blades locked in place by easily-accessible setscrews • ball-bearing mounted for smooth action • ultimate anti-roll bar tunability
![](http://www.redrc.net/wp-content/uploads/2011/08/XrayRX8ARB.jpg)
Adjustable rear anti-roll bar set allows you to quickly and easily adjust rear stiffness without replacing any parts. Features a beautifully CNC-machined roll bar body made from premium Swiss 7075 T6 and anti-roll bar blades machined and precision hand ground from world’s most exclusive Hudy Spring Steel™ that have also been specially hardened to provide extra long life and high strength. The set has two adjustable anti-roll bar blades that are locked in place by easily-accessible setscrews. The anti-roll bar is mounted to the rear bulkheads in precise ball bearings which ensure smooth action. Perfect for serious racers looking for the ultimate in anti-roll bar tunability, this rear anti-roll bar creates a noticeable difference in handling. After long term testing the XRAY R&D team has developed an anti-roll bar system with optimal flex; cutting the alu body allowing extra flex while still being stiff enough to transfer the anti-roll bar function through the blades.
![](http://image.rcfans.com/portal/201108/31/234004lj1fddx7jvyf21jr.jpg)
