XRAY Presents all-new T3 2012 Specs
11-10-15 13:31| 发布者: admin| 查看: 11753| 评论: 5
Xray T3 2012 Spec电动房车面世。T3系列电房系列获得了成功,得到了广大玩家的认可。2012 T3源于T3的优良基因开发而成,全新的底板、二楼板能够增加车架的整体抓地力,还可以提升加速时的操控性。新的舵机保护器有效提高转向精确性,齿差也被用在T3 2012新车上。滚动中心调整更简易,通用部分老款T3零件和升级零件。 相信Xray T3 2012 Spec新车的战斗力更强!Xray通知我们,新车已经开始发货至全球各地。
T3’12 New Features: • NEW chassis designs
• NEW redesigned top deck
• NEW front shock tower
• NEW rear shock tower
• NEW upper bulkheads
• NEW gear differential
• NEW steering blocks
• NEW servo saver
• NEW ball joints
• NEW servo position
• NEW optimized shock positions
• NEW optimized chassis flex
• NEW roll center positions
• Improved steering characteristics
• Increased traction
• Improved chassis balance
All-new 2012 Features in Detail: • New graphite chassis designed for increased overall traction and improved on-power steering
• New re-designed graphite top deck for increased in/out of the corner steering
• New front & rear graphite shock towers designed for new upper bulkheads
• New upper bulkheads with 3 upper linkage mounting positions
• Quick change linkage length & roll center position by shim addition/removal
• New XRAY leak-free gear differential is lighter and smoother than all other differentials; no maintenance required
• New harder steering blocks give smoother steering and cornering, prevent front tire overheating in high-grip conditions
• New 4-spring servo-saver for smoother handling and increased steering accuracy
• New closed cup ball-joints for freer movement
• Vertical servo position gives more space for electronics
• Optimized shock tower shock positions for increased on-power steering and improved high-traction handling
12下一页
    引用 ROVERED 11-10-19 12:07
    地毯坦克
    引用 J.Veiny 11-10-16 02:27
    口水都流出来了。。。。
    引用 我是奇哥万岁 11-10-15 23:14
    怎么看都像是  樱花
    嘿嘿~~~~~~
    引用 bo68674 11-10-15 15:01
    齿差。。。。。。。
    引用 ferrarifan 11-10-15 14:32
    看来要带着这个东西上船了~~~
    查看全部评论(5)
