XRAY RX8 Alu Upper Arms Holder Sets
11-9-26 23:13| 发布者: admin| 查看: 4857| 评论: 5
Xray 给他们的RX8平路车推出铝制悬挂上部承托组件。CNC工艺,7075 T6铝材制造,强度大大增强!
#342031 Alu Upper Arm Holder Right – Swiss 7075 T6 – Set
#342041 Alu Upper Arm Holder Left – Swiss 7075 T6 – Set
• Alu upper suspension holders
• CNC-machined
• Highest-grade Swiss 7075 T6 aluminum
• Includes composite front upper suspension eccentric bushings
• Ultra-strong construction
• Increased durability
Alu upper suspension holders. CNC-machined from highest-grade Swiss 7075 T6 aluminum. Composite front upper suspension eccentric bushings included.
    引用 garywong5368 11-9-28 00:38
    RC FANS : CNC工艺,7075 T6铝材制造,强度大大增强!
    引用 zengjiutiansi 11-9-27 16:31
    7075 T6铝材    抵挡吗?
    引用 luqiaoweitao 11-9-27 11:58
    它以前用的是什么材料?
    引用 2.5R飞了 11-9-27 00:58
    钛合金这两个东西就值600以上的价格.....
    引用 ACGFANS 11-9-26 23:40
    为什么不直接用钛合金?用这么低档次的铝?
    想骗钱又没档次
    查看全部评论(5)
