Hot Bodies & HPI D8S
11-10-12 13:02| 发布者: admin| 查看: 7240| 评论: 8
Hot Bodies & HPI推出D8S RTR油动越野车。装备2.4G遥控设备、手拉Nitro Star F3.5引擎。源自世界冠军D8的车架基因,D8S的悬挂和世界冠军HB D8是一样的,和Atsushi Hara版本的D8升级零件是通用的,D8S具备良好的升级能力。
Features Summary
  • Ready to Race version of the World Champion D8 buggy
  • Fitted with Nitro Star F3.5 engine
  • TF-40/RF-40 2.4GHz 3-channel radio system with failsafe and drop-down steering wheel
  • Powerful SB-5 steering servo
  • SF-10W waterproof throttle/brake servo
  • 4mm 7075 aluminium chassis with centralized weight balance
  • Easy radio tray removal for maintenance and cleaning
  • Composite chassis braces for extra driving feel
  • Lightening cut-outs under servos, engine and clutch bell
  • Tough oil-filled gear differentials
  • Spiral-cut diff gears for extra durability
  • Dual fiber disk brakes with easy-access adjustable linkage
  • Secure forward-mounted receiver & battery box
  • Unique HB solid suspension arms
  • Silicone oil-filled HB Big Bore shocks with threaded aluminium bodies
  • HB Inverse Steering Block Design front end
  • Thick steel turnbuckles
  • Total adjustability: roll centre, wheelbase, camber, sway bar and more
  • Top quality HB racing wheels and tires
  • Aluminium shock towers have multiple shock mounting positions
  • Quick access to all critical maintenance points
  • Dual bellcrank steering with aluminium drag link
  • Cam type servo saver
  • Large fuel tank with internal baffles
  • Fuel tank clunk helps engine stay running if car is upside-down
  • All socket head hardware
  • Full set of rubber-sealed ball bearings
http://www.hpieurope.com/kit-info.php?lang=en&partNo=106118
    引用 vision1 11-10-16 01:43
    具备良好的升级能力。可圈可點.. ...
    引用 阿阿道夫 11-10-14 12:03
    感觉又是HPI圈钱的.....
    引用 洋1洋 11-10-14 10:08
    期待
    引用 再见优乐美 11-10-13 19:26
    自由大帝: 5分钟前才上官网看到,一开番薯网又看到这个~~~
    番薯网。。。。好吧  你赢了色帝
    引用 梦随风飘 11-10-12 22:29
    等待价格
    引用 天堂小小虎 11-10-12 18:17
    壳子很靓,装D8Hara上啊
    引用 自由大帝 11-10-12 14:05
    引用 bear88701666 11-10-12 14:05
    配色 好看 就是不知道 rtr的 做工怎么样 期待
    查看全部评论(8)
