Hot Bodies D812
12-12-4 10:11| 发布者: rcfans| 查看: 5297| 评论: 3
Hot Bodies推出D812 1/8竞赛级油动越野车。基于世界冠军车D8研发而成,加入全新的悬挂摇臂、轻量化传动齿轮、更长行程的避震和铝制caster座等组件,除了提高车子性能外,车架的整体强度也大幅提升。一片式接收机托板,易于拆装维护,而一片式引擎座,免去每次拆装对齿轮位置的调整。D812将于近日上市。->点击这里进入HPI品牌专区参与互动
Features Summary
  • Centralized chassis weight for superior handling
  • Monocoque style suspension arms for strength, stiffness, and ease of cleaning
  • HB Big Bore threaded aluminium shocks for excellent suspension control
  • Race-optimized steering
  • Long stroke shocks for long suspension travel
  • Lightweight drivetrain gears have less rotational mass for quicker acceleration
  • Lightweight aluminium axles
  • Graphite steering knuckle arms
  • One-piece engine mount for easy engine installation without resetting gear mesh
  • Aluminium front and rear shock towers
  • CVD boots to retain grease in axles and keep dirt out
  • Adjustable hinge pin heights, kickup, and anti-squat angle
  • Adjustable rear toe-in (inboard and outboard)
  • Steel skid plate in chassis to extend chassis life
  • Aluminium front caster blocks
  • Aluminium rear hub carriers with horizontally captured pivot ball
  • One-piece radio tray
  • Fuel clunk continuous fuel pick-up even when upside down
  • Low-profile air filter
  • Front and rear anti-roll bars
  • Threaded outer hinge pins
  • Steel turnbuckles
  • Self-tightening shock mount screws
  • 2012 ROAR National Champion!
Length: 480mm
Width: 310mm
Wheelbase: 165mm
Wheelbase: 165mm
    引用 林四海 12-12-5 18:30
    看发动机是os的啊。成套3000估计能好卖
    引用 monozion 12-12-5 10:52
    继CR8流产之后,是否是HB的无奈之举.还是等等有没有什么后续的版本吧.
    引用 aorixu 12-12-4 18:59
    价格太贵的话 会不会没人买啊?
