AE RC10B4.1世界冠军版电动越野车
12-1-11 00:18| 发布者: admin| 查看: 10143| 评论: 7
官方数据:
Scale: 1:10
Power: Electric
Length: 385mm
Width: 250mm
Weight: 1535g*
Wheelbase: 281mm
Internal Gear Ratio: 2.6:1
Drive: 2WD
*Final weight will vary with the actual electronics, body, wheels and tires used to complete the
RC10B4.1 Worlds Car Kit Features:
• +8mm B4.1 chassis conversion kit
• Pro-Line Bulldog +8mm body
• Factory Team 0° rear hubs
• Factory Team rear ballast weight
• New B4.1 Worlds Car setup sheet
• Ball differential with light-weight outdrives
• Pro-Line M3 Holeshot 2.0 rear and M3 4-rib front tires
• Factory Team V2 hard-anodized threaded shock bodies with bleed-screw caps
• V2 slipper assembly with high-rate spring for more consistent slipper clutch adjustments
• CVA joints with pin retainer clips
• Durable steel center-drilled front axles
• Suspension mounts for 4°, 3.5°, 3°, and 2.5° rear toe included
• Blue titanium turnbuckles
• Complete set of precision ball bearings
• Factory Team blue aluminum hinge pin brace, milled motor plate, servo mounts and much more!
12
    引用 白色滴丶 13-6-4 21:26
    喜欢外形
    引用 jjr202556 12-8-25 07:37
    zwtnt168: 这设计的,还越野,齿轮给扫掉!
    哥们,这外面有个罩,谢谢,这只是给齿轮的一个特写
    引用 crusaderlyf 12-1-13 18:24
    ae可是越野的老大哥,兄弟看这张图片太片面了
    引用 干逸成 12-1-12 16:12
    不愧是世界冠军版本..
    引用 zwtnt168 12-1-12 13:15
    这设计的,还越野,齿轮给扫掉!
    引用 jakesen 12-1-11 19:25
    马达固定座不好看~
    引用 crusaderlyf 12-1-11 17:45
    worlds car一出,预示着B4系列就此终结?可以参照当年rc10,rc10 worlds car是rc10系列最后一台
    查看全部评论(7)
