Spektrum DX18遥控器
12-2-28 17:08| 发布者: rcfans| 查看: 9085| 评论: 3
Spektrum最新款的DX18遥控器月初在德国纽伦堡模型展上首次亮相。这是一款18通道,可编程的高端航模遥控,适合各类遥控飞机、滑翔机和直升机使用。DX18使用了最新的DSMX和X-Plus技术,可存储50组模型参数,内置震动提示的遥测系统,16组可混合编程模式。Spektrum DX18的售价肯定比FUBATA18MZ便宜,不过18MZ的功能还是要比DX18强劲不少。DX18应该是一款性价比高的顶级航模遥控设备。
特性:
50 Model Memory
Built-In Telemetry with Vibe Alerts
Extensive Airplane, Helicopter and Sailplane Programming
Throttle Start or Switch Start Timer
Region Settings for Global Compliance
16 Programmable Mixes
Flap Delay and Elevator Compensation
10 Airplane Wing Types
6 Airplane Tail Types
5 Airplane and Heli Flight Modes
Dual Rates and Expo
Active Gyro Trim
7-Point Heli Throttle Curve
7-Point Heli Pitch Curve
7-Point Heli Tail Curve
6 Swash Plate Types
Swash Plate Timing
5 Sailplane Wing Types
3 Sailplane Tail Types
10 Sailplane Flight Modes
Global Charging System
欢迎进入RCFans直升机、固定翼讨论区参与讨论
http://www.rcfans.com/bbs/forum.php?gid=22
    引用 T2011K 12-3-20 18:01
    引用 shi995800 12-2-29 22:32
    18个通道好生之多,还有24的吧
    引用 ledledled 12-2-29 12:24
    不错!多少钱?
