Features:
- Long-lasting battery pack and charger
- 2-in-1 ESC/receiver combo unit
- Powerful micro motor
- Adjustable, composite, coil-over shocks
- Durable, molded composite chassis
- Shaft-driven transmission gear differential
- Micro all-terrain Kingpin tires
- Simple bottom-load battery compartment
- Threaded axles (no e-clips required)
- Dish racing wheels
- Micro steering servo
- Fully decorated truggy body
Specifications
Type: 4WD Micro Truggy Scale: 1/24 Length: 6.13 in (156mm) Width:
4.25 in (108mm) Wheelbase: 4.18 in (106mm) Weight: 5.3 oz
(165g) Chassis: Extended composite tub Suspension: Independent
4-wheel Speed Control: Electronic, fully proportional Radio: Pistol-style
AM 27Mz Batteries: 4.8V 220mAh NiMH (included) Charger: Peak wall charger
(included) Kit/RTR: RTR Minimum Age Recommendation: 14 years Experience
Level: Beginner Recommended Environment: Indoor/Outdoor Is Assembly
Required: No
 欢迎进入RCFans迷你遥控车讨论区参与讨论 Source:http://www.horizonhobby.com.cn/ |
