JR Propo新款3D直升机
12-3-5 23:58| 发布者: rcfans| 查看: 7520| 评论: 5
JR Propo推出新款3D电动遥控直升机——Vibe SG E12 FBL。这款产品虽然沿用了SG12 E12名称,但是多个组件已经进行了升级,包括更坚固的机架、铝制旋翼和更强壮的升级Swashplate等,支持520KV至450KV无刷马达。Vibe SG E12 FBL已经在日本上市,相信很快会进入中国市场。
Flagship electric 3D helicopter, VIBE SG E12 FBL is just released in japan.
This model is renewed from previous model, VIBE SG E12. Here are the changes from previous model.
  • Main Frame L/R became simple in design but rigidity has increased.
  • New painted FRP Canopy
  • The Upper Swashplate has been improved. The Ball arm with 3mm screw is used for increase in durability.
  • The Main Gear has been changed to Helical type, T93.
  • Pinion gear T9,T10 and T11 are included.
  •  Aluminum Rotor Spacer is used to hold the main rotor blade more tightly.
  • Autorotation Assembly and Autorotation sleeve have been changed.
  • Metal part is now used to bearing so that the weight has got much lighter.
Vibe SG E12 FBL Specifications
Overall Length 53.50in
Overall Height 16.73in
Overall Width 7.16in
Main Rotor Dia. 63.18in
(with 720mm main rotor blades)
Tail Rotor Dia. 11.33in
Gross Weight 7.93lb or more
(not including main rotor blades and Battery)
Gear Ratio
[T9] 10.3:1:4.65
[T10] 9.3:1
[T11] 8.45:1
Battery Guide:
6cell 22.2V 4500-5500mAh Lipo (2pcs)
Length 175mm (maximum)
ESC Guide:
Li-po compatible 12cell 100A or greater
Motor Guide:
[T9] KV500-520
[T10] KV500-520
[T11] KV450
    引用 super_弟 12-3-7 21:58
    有人想要金属齿轮,,,买个玩具玩玩把、、、、、、、、、、
    引用 li3488087 12-3-7 19:32
    竹仔鱼: 垃圾,还是塑料齿轮。3D直升机还是小的好,安全。
    你行不行
    引用 免贵姓徐 12-3-7 19:05
    直升机 伤不起啊 。。。。
    引用 蜡包 12-3-7 16:24
    不懂别乱说,飞机就没有安全的,都不能碰人。JR的飞机都是顶级的,米得很。齿轮你还想金属的?
    引用 竹仔鱼 12-3-7 00:01
    查看全部评论(5)
