Team Associated推出SC10GT油动短途卡车
12-4-5 19:43| 发布者: rcfans| 查看: 9160| 评论: 11
Team Associated推出SC10GT油动短途卡车(short-course)。基于原厂成熟的GT2车架开发而成,装备Team Associated.18X手拉引擎和排气系统。强劲的引擎动力通过可调V2限滑器传递到车轮上,齿比4.09:1。原车已经装备轻量化传动轴杯和高抓地力的Jconcepts竞赛轮胎。由于是RTR产品,遥控器方面2.4GHz设备已经成为大部份RTR遥控车的标配,这辆SC10GT也不例外。
Features
Low center of gravity transmission with 4.09:1 ratio produces the ultimate in torque with proven ability to transmit all the power to the ground, which makes for ground-shaking speeds not usually seen in RTRs.
V2 Dual disc slipper clutch.
Modular radio tray that easily removes for cleaning and maintenance, and protects the receiver against fuel spills during pit stops.
Optional high capacity 150cc fuel tank fits in standard radio tray for longer run times.
Special tuned exhaust system, which produces a perfect balance of maximum power and efficiency.
V2 Blue anodized aluminum shocks.
All-new sealed battery box.
Blue anodized aircraft aluminum chassis. Chassis design adds tremendous rigidity for the ultimate in consistency and handling.
Radical pre-painted body shell that any pro painter would be proud to produce.
Our proven #2918 AE .18X engine will shock customers with its power and speed.
High-traction JConcepts™ racing rear tires for consistent handling and long life.
Ball differential with lightweight outdrives.
Shielded bearings throughout the truck.
Glow igniter and fuel bottle included.
AE logo mud flaps.
12下一页
    引用 武汉螃蟹 12-4-7 21:31
    注意看空滤。。。
    引用 super_弟 12-4-7 19:17
    “这好像是有史以来第一辆1:10油动后驱短卡。”其实hpi的油2wd卡车如果装了blitz的防撞,如果行的通。这台就不是第一台了、、、、、
    引用 hhvw123 12-4-7 19:02
    虽然FR的操控加速都很好且·快,但还是喜欢相对安全的4WD多些
    引用 武汉螃蟹 12-4-6 22:32
    价格价格。。。
    引用 ferrarifan 12-4-6 20:30
    抬头车???
    引用 hxrl1986 12-4-6 12:32
    失败啊。。。。和SC8比简直差老了!
    引用 树袋熊zz49 12-4-6 00:04
    这颗引擎太像雷虎的风格了!没半点花哨。悬挂是SC10改进而来的吧,好眼熟!
    引用 给捷达装V8 12-4-5 22:49
    终于出油动1/10短卡了!!
    引用 邦德座驾 12-4-5 20:58
    引用 abc56725690 12-4-5 20:29
    遥控和S50一模一样
    引用 林四海 12-4-5 20:00
    这货是雷虎的外资平牌
    查看全部评论(11)
