Team Associated厂队版RC12R5.2
12-8-8 17:12| 发布者: rcfans| 查看: 10541| 评论: 2
Team Associated推出 RC12R5.2厂队版(Factory Team kit),基于R5.1车架研发而成。产品属于竞赛级1/12电动房车(12仔),使用三点式尾部悬挂系统,让车架支持各品牌的无刷马达,蓝色的金属组件除了非常美观之外提供更好的强度。2.5mm碳纤底板,可使用R.O.A.R认可的3.7V锂电。新车将于本月上市。 欢迎进入AE/雷虎品牌专区参与讨论,点击这里进入
Features:
  • I.F.M.A.R. World Championship-winning Dynamic Strut front end features symmetrical components with adjustable caster and track width, and includes updated lower control arms for more precise mounting
  • Updated motor mount and left rear bulkhead for increased durability
  • Brushless motor optimized 3-point upper pod plate with graphite motor mount cross-brace
  • Ultra-rigid 2.5mm thick chassis featuring centralized LiPo battery mounting position that fits R.O.A.R.-approved 3.7V LiPo battery packs
  • Aluminum side spring retainers for easier and more accurate adjustments
  • Innovative through-shaft center shock
  • Side damper tubes for freer rear pod movement
  • Pivot-Ball rear pod design with hard anodized aluminum pivot balls and updated rear pod links
Specifications:
Scale: 1:12
Power: Electric
Length: 273mm (10.75″)
Width: 170mm (6.7″)
Weight: 225g (7.94 oz.)*
Wheelbase: 199mm (7.83″)
Internal Gear Ratio: 1:1
Drive: 2WD
    引用 那个悲剧啊 12-8-11 20:02
    轮毂好漂亮,可是太宽
    引用 yu43085251 12-8-9 11:00
    漂亮啊    我们这里找不到适合的场地玩
